Open Water
This is a crack a making a water purifier for less than 20$
1 in 9 people lack access to clean water (according to water.org). Some people like to go camping. While tons of water purifiers exist, I wanted to make a really cheap, reusable water purifier.
I did a cost analysis for my board.
Item
Price at 1
Price at 100
ATTINY 85
1.24
1.03
8 Pin DIP Socket
.18
0.11958
33 uF Capacitor
.23
.0858
1 uF Capacitor
1.54
.9502
9v Battery Snap Connector
.97
.89
5v Linear Regulator
.5
.3184
Bulb Holder
3.77
1.48
9v Battery
1.30
1.15
MOSFET
.95
.576
Slide switch
.48
.3858
Push Button
.17
.1457
UV lamp
7.72
< 7.72
Piezo transducer
.67
.42
Resistors
.25
.1
PCB board
5.65
.33
Electronics Subtotal
25.62
15.69
Board housing
1
.5
Total
26.62
16.19
 I went a little over budget for my prototype, but when I use the Digikey price at 100 for components, and use PCB way's estimate for boards, It is under 20 dollars!
View all 13 components
  • Update #2
    Becky Button10/14/2018 at 00:39 0 comments
    Sending the board to OSH Park!!!
    16.95 $ for 3 boards!!
  • Update #1
    Becky Button10/13/2018 at 23:58 0 comments
    A lot of progress has been made on the board so far!! As of today, I have completely traced out the board, and will be sending it off to OSH park later today.
    Please note that this is only showing the front copper, so some traces are not present in this representation of the board.
View all 2 project logs
zachary.parksey wrote 10/15/2018 at 04:01 point
Neat idea!  Is the purification provided by strictly UV from the lamp, or is the focus on the generation of ozone?  I've fiddled with the idea of miniaturized and high-throughput ozone generation, myself...using the generator for ozonolysis at work has always been an 'inspirational' process, anyway.
Becky Button wrote 10/20/2018 at 18:13 point
I was looking at purifying using the UV lamp.
