Journey SBC
My educational journey into the development of a single board computer.
Public Chat
I really want to step up my open source hardware game and learn embedded Linux architecture and design. I figured the best way to do this was to build my own computer. This project will document the process from schematics & board layout all the way to bootloader & drivers.
I will be using existing reference architectures and implementations as guide-rails. I want to avoid breaking new ground at the same time I'm trying to learn. This project will be based on the Allwinner A13 System On Chip (SoC) reference architecture. There are already embedded Linux implementations of it in the wild, so support & drivers shouldn't pose an issue. Plus, parts are cheap and readily available from AliExpress.
Project Goals:
- System core of Allwinner A13 SoC with DDR3 RAM
- Power Management Unit (PMU) with LiPo charging & battery
- On board NAND flash storage
- TFT/LCD screen
- Wi-Fi & Bluetooth
- GPIO pinout
- UART pinout and/or USB
- ADC for sensors
Project approach:
I will initially segment design and prototyping into a base motherboard that contains the CPU & RAM with add-on boards for peripheral functions (i.e. Wi-Fi, BT, flash storage, etc). The theory here is that I can get comfortable with each peripheral function without having to spin a new board that contains everything each time I mess something up. After I get everything working, I will then design a single board that contains everything.
I'm going to start this project, and hopefully finish, by only using KiCad and OSH Park. I want to see how far I can get with open source and what tools and suppliers are easily available to the maker and hobbyist community.
  • NAND Flash Building Block v1
    Kevin Neubauer11/25/2018 at 04:20 0 comments
    I thought I would have no way of building a standalone peripheral PCB for testing out the NAND flash chip I wanted to use. I had no CPU & RAM mainboard yet and no other interface chips to work with the raw flash. Then it hit me. At the Hackaday Supercon this year, I took an FPGA workshop that was led by @Piotr Esden-Tempski. It was called "WTFPGA?" and I would highly recommend it if you want an into into FPGA technology. I looked around for existing OSHW designs to use (because why reinvent the wheel?) and lucked out. A company called Waveshare produces a (mostly) OSHW FPGA NAND interface board. They publish the schematic and pictures of the board, but I could not find board layout files. However, I am confident that with the schema and pictures, I could reproduce what I need for my flash chip.
    After drawing up my own schematic, I set to work on the board layout. This board should allow me to test out my NAND, and after I'm done with it, I will be left with an added bonus. I will have a NAND module to play with for my new FPGA setup.
    Four layer board stack-up:
    • Top: Signal traces and components. Remaining space filled with ground pour.
    • Layer 2: Ground plane
    • Layer 3: 3v3 Power plane
    • Bottom: Signal traces. Remaining space filled with ground pour.
    Components:
    • SK Hynix H27UCG8T2ETR-BC TSSOP48 NAND (8 GB)
    • 0603 Passives
  • V1 Wi-Fi & BT Building Block PCB
    Kevin Neubauer11/16/2018 at 21:40 2 comments
    See here for the initial board stack up and features. Things haven't changed a lot between the initial draft and now. What has changed is via stitching/fencing, and the use of 2.54 mm header pins instead of the 1.00 mm header pins. I hate making a bigger board than I need for components, but it is what it is. 1.00 mm header pins aren't cheap or easy to find.
    KiCad files posted to my GitHub. Link is on the main project page. If you like this design block and want to use it in any of your projects, you may want to wait until I get this assembled and tested.
  • RF & Via Stitching/Fencing Pt 2
    Kevin Neubauer11/16/2018 at 03:36 0 comments
    Based on a tip from @amorim317, I found this article on via stitching that helped to explain why my original numbers were off. Turns out I was not factoring in my FR4 substrate into the equation. The original equation that I found only looked at the wavelength of the RF frequency in a vacuum, not its propagation through the FR4.
    Based on the info in the above article, my via fence spacing in meters should be:
    Where:
    = Wavelength in a dielectric medium
    = Speed of light (299,792,458 meters/second)
    = Frequency (In this case 2,450,000,000 cycles/second)
    = Permittivity or dielectric constant of material (In this case 3.66)
    The frequency I'm concerned with is 2.45 GHz (2,450,000,000 cycles/sec). The dielectric constant of the 4 layer FR4 that OSH Park uses is 3.66 @ 1 GHz. If you look at the data sheet, it says 3.67 @ 2 GHz. I'm just going to use 3.66 because the difference is small, I'm lazy, and it's what I've already used to calculate my 50 Ohm transmission line.
    Give the above, for my RF via fence we end up with a max distance of:
    S(via) = 299,792,458 m/s / (20 * 2,450,000,000 * 1.913) = 0.003 meters * 1,000 = 3 millimeters
    The article referenced above also recommends containing RF at board edges by using via stitching at wavelength/8 instead of wavelength/20. This means my edge via stitching should be separated by a max distance of:
    S(via) = 299,792,458 m/s / (8 * 2,450,000,000 * 1.913) = 0.0079 meters * 1,000 = 7.9 millimeters
    All of the above is very helpful in understanding the calculations involved in via stitching/fencing. If you're still reading, here's your reward: An easy to use calculator for TEM wavelength calculations! Take the result of the calculator divided by 20 to get RF trace via fencing max distance. Take it divided by 8 to get board edge via stitching max distance.
    All of the above is great for validating your via spacing decisions. However, it doesn't factor any error or material differences or variability into the equation. I'm going to err on the side of extreme caution on my RF trace fence and use 1 mm spacing and cut down my board edge stitching to 5 mm.
  • Always Print PCBs at 1:1 Scale Before Fabrication
    Kevin Neubauer11/15/2018 at 02:42 0 comments
    I was just about to pull the trigger on ordering my Wi-Fi / BT board when I figured I should print it out on paper to double-check footprints. After printing at 1:1 scale, I realized the header pins were super small. I hadn't realized that I assigned a 1 mm pin footprint to my header part instead of a 2.54 mm (0.1")! I was probably distracted when I did it and equated 0.1" to 1 mm. I did look for a part source for the 1 mm header pins, but they were either expensive at around $7 for 50 pins or they had to ship from China. I decided to update the footprint.
    Assigning the correct footprint, regenerating the nets, and then updating the nets in the PCB editor resulted in an immediate facepalm. I had to resize my board, rip up a bunch of traces, and then re-run them. The new board has a bunch of dead space on it, but it's needed to accommodate the larger header pin footprint...
    Anyway, here it is. I'll likely order it tomorrow. After assembly, I'm going to see if it works and benchmark signal and throughput by using a Raspberry Pi.
  • Wi-Fi & BT Perhipheral Board Progress
    Kevin Neubauer11/14/2018 at 05:25 2 comments
    Why not start with the second hardest concept? I've never done RF design before, so this took quite a bit of reading. I read (mostly read, some skimmed) several white papers on RF PCB design before tackling this board. "Antenna Design and RF Layout Guidelines" by Cypress Semiconductor was approachable and well written.
    Components:
    • Realtek RTL8723BS module
    • Unictron AA055A Wi-Fi & BT chip antenna
    • 0402 Passives
    Via Stitching/Fencing:
    • In each corner and along board edges to arrest stray EMI from the power plane
    • Fencing around RF keep-out zone & transmission line
    • Between ground pours and ground plane to help maintain low inductance and provide short return loops
    • All stitching and fencing was done between all GND pours and the internal GND plane
    Other Notes:
    • 50 Ohm impedance trace between RTL8723 antenna pin and chip antenna
      • Calculation done using KiCad built in calculator for "coplanar wave guide with ground plane" and OSH Park 4 layer specs
    • Uninterrupted ground plane under RF transmission line
    • Keep-out zone under chip antenna per Unictron datasheet guidance
    • CNC cutout in keep-out zone per Unictron datasheet guidance
    [Edit: The below calculation was wrong! I should have trusted my intuition and done more digging. :-) User @amorim317 helpfully pointed out that the below calculation does not factor in the substrate and its dielectric permittivity. Click here for new numbers.]
    It seemed very difficult to find clear guidance on via fencing & stitching for RF layout. Most Internet sites refer to the frequency wavelength/20 guidance for determining spacing. However, they don't specify units and don't give examples! Frustrating to say the least, but it turns out it doesn't matter. It literally is as simple as finding your wavelength and dividing by 20... However, at the time I didn't think anything in RF design could be that simple, so I traced back to the source of this guidance. It originated from an IEEE Press white paper published in 1999 that was titled "EMC and the Printed Circuit Board. Design, Theory, and Layout Made Simple" by Mark Montrose. Section 2.9 of this paper gives the equation used along with a reference table of miscellaneous frequencies. Using this information, I was able to calculate the via stitching needed for 2.4 GHz. I used the middle of the band @ 2.45 GHz. The wavelength for 2.45 GHz is 122.45 mm. Take that divided by 20 and you get 6.1225 mm. My fence around my RF trace needed to have vias spaced 6 mm apart. After looking at 6 mm on my board and seeing how far apart it was compared with commercially produced 2.4 GHz PCBs, I decided to follow existing examples as closely as I could and use 0.75 mm stitching for both my RF fence and around the board edges and 2.5 mm stitching to join the ground pours with the ground plane. Extra vias on a small run board equals cheap insurance...
View all 5 project logs
