new found motivation
11/05/2019 at 09:21 • 0 commentsI still need to make this work / compile with all the feathers, sounds like a good software project for my vacation, right? The PCB
could getgot an update too, all 8 inputs and 8 outputs on a header.![]()
Finally working prototypes
01/26/2019 at 18:34 • 0 commentsAfter I read 2.7V on the VCC pins it finally made click - the VCC pins weren't connected to the 3.3V pin, but got voltage through diodes on the enable and SPI pins. This made me so happy, that I bought some new boards and parts and I will make this a tindie product at one point.
boards ordered
10/16/2018 at 08:17 • 0 commentsI did something I haven't done before on this board, a matrix to reroute pins with solder jumpers. Otherwise the board looks fairly simple and boring, not much to route on it.
davedarko
