Mechanicals Hotkeys
A mechanical keyboard for shortcuts with Arduino Pro Micro. It automate the generation of new password and puts on clipboard
It is a pcb for cherry mx keys, each key has its own led and is based on Arduino Pro Micro. One of the funcion it's automates the generation of new password and puts on clipboard.
You can add new function to every key, and make the led response according to the function. The led it's connected to pwn.
Check the github link to see the source code.
  • 1 × Arduino Pro Micro
  • 4 × led 3mm
  • 4 × resistor 470
  • 1 × Custom pcb
  • 4 × mechanical keys
  • New pcb design
    Guille • 10/26/2018 at 13:32 • 0 comments
    I redesigned the pcb, with a different design for the keys; add a rotary encoder to take better advantage of the arduino space.
    One of the advantage of this design, is the a can do a better panelize de boards.
  • 3D Print cabinet
    Guille • 10/16/2018 at 14:13 • 0 comments
    Make a custom cabinet to print in 3d for the keyboard.
View all 2 project logs
View all instructions
