it feels like midnight, so no order!
A project log for Game Boy Cartridge plus Programmer
not the first cartridge on this platform
davedarkodavedarko 11/15/2016 at 19:007 Comments
Almost every pin is in use or broken out! I've ran all checks that eagle offers me, but I refuse to order because of the time!
There'a a via on the power line on the right o.O - fixed
So beautiful! - Sometimes I only upload them to see what they would look like :3
This is the LCD board that I also have to check again and order soon, not just this evening. It makes sense to have this separate, since the game boy classic also had a separate lcd board - so that's what I do, staying original :D I should make one pin header side 5V and one 3.3V and add some level converting stuff, before I order.
Ted Yapo wrote 11/15/2016 at 22:10 point
It sounds like a wise rule!  I had a board ready to go this weekend, but got distracted and forgot to send it.  I looked at it again this morning, and ripped up all the traces and re-routed it.  It's funny how different things can look after a day or two.
Eric Hertz wrote 11/15/2016 at 21:09 point
Your "because of the time" sentiment regarding ordering PCBs keeps coming up... I was trying to chug one through last night, now it's midday... probably best to wait a day or two.
davedarko wrote 11/15/2016 at 21:20 point
well the rule could be adjusted to "sleep over it", not actually implying when to be asleep ;)
Stefan-Xp wrote 11/24/2016 at 23:33 point
For PCBs roughly the same rules apply as for Gremmlins.
Don't order after midnight ;-)
BTW: Why does it appear as C1..C4 are only connected on one side? Ahh... Well because they are connected to Ground and the Polygon is not active ;-)
BTW: What are those holes for? If you want to use screws, then the ISP Header is maybe a bit near? For M3 Screws i also like to use vias with 3.2mm drill and 5.0mm Diameter, so the Screwingplace is almost safe :)
BTW: What are thos circles beside the drills?
Best regards and don't make the gremmlins angry ;)
davedarko wrote 11/25/2016 at 06:43 point
@Stefan-Xp
The Ground polygon gets me too sometimes, but they're so handy.
The circles and drillholes are for the socket, it has a big and a smaller hole next to each other. The circle is drawn on the dimension layer since there is no drill big enough for it.
Stefan-Xp wrote 11/26/2016 at 07:41 point
Thank you. Some Board Houses are offering milling for free, maybe you could also put it on the milling layer...
davedarko wrote 11/26/2016 at 10:55 point
The milling layer hmm. I have another board (the LCD one) at order that will use this layer. Seems like I just have to wait on all the things ordered and see what works and what not :)
