CAD
A project log for TranspOtter NG
TranspOtter? TranspOtter is an (autonomous) traffic concept that follows you and transports loads in everyday life.
jana-marieJana Marie 11/07/2018 at 07:300 Comments
TranspOtterNG started with quite alot of CAD work, as the first TranspOtter was build from scratch and therefore had potential for improvement.
https://github.com/Jan--Henrik/TranspOtterNG/tree/master/CAD
The main problem of TranspOtter (1.0) was in the end, that the wooden frame broke. This was caused mainly by weak wood but also by the motor mount. To fix that, we want to use multiplex wood, which is in general much stronger and milled motor mounts instead of the hoverboard frames.
