Assembling a head from the printed and laser cut parts
A project log for Open Animatronics
A modular, parametric and extensible Animatronics cad generation framework
Kevin HarringtonKevin Harrington 12/29/2016 at 14:552 Comments
Here is a step-by step of the assembly of the animatronics part of the head. To get the printed pieces from bowler studio, right click on them and export to stl. NOTE! the two different color eye stocks are mirror images of each other and you need 2 of each! The connector cup however is universal and you need 4 of the same part. You need to print 10 pieces in total, and they all can be printed by a standard FDM printer during the period of time it takes to assemble the wooden sections. (which is why the printed pieces don't show up until the end ;)
You can also get a glimpse of the first production prototype of the animatronics backpack for the NodeMCU that powers the system. It has screw terminals for the battery and 2 dc signals connected each to an h-bridge. The wiimote connects with a simple PCB connector and does not need to be modified for use with this kit. The servos all have thier own connectors, one per IO pin on the NodeMCU, although some conflict with the h-bridge, so when using it, you get a limited number of servos. It is quite frankly the most useful hacking tool i have ever used... Awesome Job Alex Camilo for designing, manufacturing, and assembling the whole backpack!
Nate Bowen wrote 01/25/2020 at 18:34 point
I got this kit and its contents where black! And they aren't even the same pieces. Do I have the more modern version?
Andrew wrote 02/12/2021 at 16:56 point
Hi Nate, It sounds like I have the same issue. Did figure anything out?
