Finished the schematic
A project log for Himnull - A Raspberry Pi E-Reader
Making an open source e-reader for less than $75.
repkidrepkid 10/11/2016 at 13:060 Comments
The title's pretty self-explanatory. Turns out KiCad is pretty intuitive to use. This is the schematic for the board that will act as the interface between the RPZ and the EPD. Next I'm going to create the PCB design. Should be up in one or two days. And the source files for this magnificent schematic will be uploaded once I clean things up a bit.
