WiFi + Websockets + ESP
A project log for Hacking Cellphones Overview Project
Cellphones have so many useful bits: it's a shame that they're hard to us in projects. Let's fix that!
elliot-williamsElliot Williams 10/19/2018 at 15:330 Comments
[murilopolese718523034] suggested WiFi + Websockets + ESP32 running Micropython.
Websockets are great b/c you could code the app on the phone side as a webpage, which makes it more portable and relatively easy to hack together if you know HTML / JS.  It's also (relatively?) low latency, at least compared to HTTP.  Which is faster, Bluetooth/Serial or WiFi/Websockets?
I also like this b/c the hardware side is pretty easy to handle.  Just an ESP32 and you're done.  Let its HW peripherals handle the SPI or I2C or ADC or whatever.
What's missing is a protocol/API.
Micropython here or there, this is a promising approach to tacking fairly high quality GPIO onto a phone.
Pros: cheap, readily available, super-flexible hardware
Cons: battery drain from WiFi, flexible -- protocol implementation needed
This is the angle I'm going to chase down.  I've got some ESP32 breakouts just asking to be used...
