Functional Hardware
A project log for Neopixel Clock
Basic Wall Clock using Neopixels, and Arduino Mega and a RTC breakout pcb.
ShaneShane 10/22/2019 at 03:450 Comments
I worked past some faulty neopixel's with new parts.  The clock worked well, the every second worked, the minutes shifted and the hours lighted up.   Next will be to get the time adjustments working, I replaced the photo resistors with switches.  After that I need to figure out why the programming is not working with a FTDI adapter.
