Xpansion20181025.zipIn progress KiCad 5 files with partially implemented 595 Shift Register and LED's. Uses footprints from digikey KiCad Library.Zip Archive - 550.96 kB - 10/26/2018 at 00:14 |
Xpansion-F.SilkS.svgSimplified outline, scaled to 1:1 with mm unitssvg+xml - 105.36 kB - 10/25/2018 at 23:48 |
Xpansion-Edge.Cuts.dxfSimplified outline, scaled to 1:1 with mm unitsAutoCAD DXF - 35.99 kB - 10/25/2018 at 23:48 |
Supercon2-Edge.Cuts.dxfSimplified outline, scaled to 1:1 with mm unitsAutoCAD DXF - 25.48 kB - 10/25/2018 at 23:48 |
Xpansion-Edge.Cuts.svgSimplified outline, scaled to 1:1 with mm unitssvg+xml - 5.96 kB - 10/25/2018 at 23:48 |
16-SOIC.pngReference IC footprint for 16-SOIC at 640ppiPortable Network Graphics (PNG) - 47.54 kB - 10/23/2018 at 20:23 |
16-TSSOP.pngReference IC footprint for 16-TSSOP at 640ppiPortable Network Graphics (PNG) - 21.37 kB - 10/23/2018 at 20:23 |
8-SOIC.pngReference IC footprint for 8-SOIC at 640ppiPortable Network Graphics (PNG) - 18.95 kB - 10/23/2018 at 20:23 |
16-LGA.pngReference IC footprint for 16-LGA at 640ppiPortable Network Graphics (PNG) - 9.03 kB - 10/23/2018 at 20:23 |
breakout.xcfBase photo of board used for reference to determine mechanical dimensions and general layout.x-xcf - 8.20 MB - 10/23/2018 at 20:22 |
