First test after full assembling:
100 WS2812 LEDs driven by a Raspberry Pi Zero in a cylindric shape out of laser cutted parts
As in my previous LED matrix project, I am using a pygame based simulator for testing the python code on the PC. Code will follow soon on Github.
Here are some more pictures from the LED assembling:
It is splitted into two parts to simplify LED assembling and cabeling.
Height is 18 cm, diameter is 20 cm
it is a veneer paper called microwood: http://www.microwood.com/information
What have you used as a light diffuser? Paper ?
