500W Power Inverter With Reverse Polarity Protection
Hi friends. I have TG500 UPS but it have some problem so, i use it's transformer, mosfet,diode,capacitor for make new Inveter. I hope you like it.
In video below i show you how to make 500w inverter. With the electric component from UPS Tg500.
Make PCB With My Gerber File
I use Eagle software for make layout and make gerber file, after that i upload to https://jlcpcb.com/m for make PCB online, you can make it by yourselt at home. You can download all file here with include Schematic (TG500) gerber and PDF file.
Prepare Component and Solder to PCB. You can order them from LCSC.COM
(IRF95N03 SMD X2) STD45N10F7 SMD X2 : https://bit.ly/2Jy6x1b
R 10K X2 : https://bit.ly/2P2XR9c
R 10 X3 : https://bit.ly/2CZmTyW
R 1K : https://bit.ly/2SG20xS
UPS TG500 TRANSFORMER : Take from old TG500 board
DIODE MUR 460 X4 : https://bit.ly/2QeNoUN
R 0.47 /2W : https://bit.ly/2CVP7KS
Trimpot Variable Resistor 6MM 5K :https://bit.ly/2qob65F
CAPACITOR 450V/100UF : https://bit.ly/2EZeDS2
CAPACITOR 3300UF/35V : https://bit.ly/2PGxqpu
12V FAN : https://bit.ly/2SH6Bjj
IRF3205 X2 : https://bit.ly/2PzDv72
Header 2P XH2.54-2P X3 : https://bit.ly/2JxSVTB
2.54mm 1X40P Single Row 90 Degree Curved Needle Connector Pin Header : https://bit.ly/2yON8oK
SG3525 (KA3525) : https://bit.ly/2Rt8lvl
CAPACITOR 10UF/16V : https://bit.ly/2qpQLN7
CAPACITOR 104 X2 : https://bit.ly/2P17c18
CAPACITOR 102 : https://bit.ly/2QeOhN7
R 20K : https://bit.ly/2zx0w0r
R 47 : https://bit.ly/2qscPXn
R 150 X4 : https://bit.ly/2JxTcWD
My inverter have 310V DC of ouput. I can run TV,laptop,computer can not run fan,ac motor Becareful with high electric voltage
REVERSE POLARITY PROTECTION
youkito1991
ajari saya tentang lilitan pada trafo yang anda gunakan tuan 🙏
