Designing a Power Conditioning Module
A project log for Street Sense
Portable electronic device to measure air and noise pollution
mike-teachmanMike Teachman 06/19/2019 at 14:130 Comments
Building the power conditioning module for the particulate sensor is the subject of this log.   The components in this module include all of the MOSFETS, transistors, diode, and the DC-DC boost converter.   An overview of the modules was described in Modular Design Concept
The purpose of this module:
  1. Provide 5V power to the particulate sensor, for both USB and Battery power
  2. Provide a 3.3V compatible digital signal that will allow the MicroPython code running on the ESP32 the ability to turn off the DC-DC converter.  Turning off the DC-DC converter eliminates the power consumption and noise of the particulate sensor
The components are shown below.  The full schematic is here:  schematic.
A soldered protoboard will be used for construction.  For protoboard, I either use Adafruit Perma-Proto (left in photo below) or a generic stripboard (right in photo), cut to a custom size.
The Adafruit product is high quality - the through holes are accurately drilled and plated.  The stripboad is somewhat lower quality - no though hole plating and inconsistent drilling which can lead to track lifting if there is any rework.  The photo below shows some of the off-center drill holes on the stripboard.
Sloppy drilling in stripboard
However, compared to a Perma-Proto board a stripboard module can be designed with a denser component layout, leading to a smaller module.  In the end, the need for a small module size led to the selection of stripboard.
Related stripboard idea:   There is high quality stripboard that is available, but it comes a significant price premium.  I think it might be possible to design a stripboard in KiCad and then have it built by a custom PCB manufacturer.  I am seeing low-cost PCB manufacturers offering 3 PCBs (10cm x 10cm) for USD $10 + shipping.   These PCBs would have plated through holes and solder resist between the holes, and hopefully accurate hole placement.  I might explore this avenue and document the results in a Hackaday project.
The completed power conditioning module is shown below.  I am using polarized JST connectors for connection to the particulate sensor and cpu module.
