I decided to redo the power conditioning PCB module. For these reasons:
- Make a slimmer version that will allow space for the LiPo battery to fit inside the vented enclosure
- Add 4 mounting holes for standoffs
- Add more test points and jumpers to facilitate voltage and current measurements
- Get more experience using KiCad for Stripboard layouts
Using KiCad, it was straightforward to iterate the stripboard layout to reduce the PCB width by about 25%. This task would have been more difficult and time consuming using hand layout methods
The first version of the power conditioning module is described in an earlier project log
Here are photos of the new, slimmer power conditioning module
LiPo battery and module now fit side-by-side inside the vented enclosure
25% slimmer compared to the first version of the power conditioning module (on right)
Layout in KiCad
The schematic is here
As with all aspects of this project, it's 100% open software and hardware. The KiCad files can be found in the Street Sense GitHub repository
Mike Teachman
