Top Wall Mount Touchscreen for ESP8266
Touchscreen for top wall mounting for ESP8266 & ESP32
Public Chat
The popular ESP8266 and ESP32 based modules are used in many IoT applications like home automation, smart lighting, smart metering, remote control etc. You can find a lot of ready to use projects in the Internet. AZ-Touch is a touchscreen enclosure set especially for top wall mounting for the well-known NodeMCU and Wemos D1 Mini boards based on ESP8266 and ESP32 platform.
AZ-Touch come in a nice enclosure for wall mounting together with a 2.4 inch resistive touch screen and enables you to mount your project permanent in your living room, corridor or other exposed places.
  • top wall mounting enclosure
  • 2,4 inch (6,14 cm) tft screen with 320 x 240 pixel resolution
  • SPI display controller ILI9341
  • Resitive touch with SPI touch controller XPT2046
  • Integrated 5V/1.4A voltage regulator (Vin 9...35V DC)
  • Integrated prototyping area
  • 6-pin removable terminal block for prototyping area & power supply
  • Marked and connected GPIO & power pins beside the proto area
  • Integrated piezo beeper
  • Plug-in positions for Wemos D1 Mini, NodeMCU Amica V2, NodeMCU ESP32
  • Vented cover to allow through air flow
Adobe Portable Document Format - 425.35 kB - 12/18/2018 at 06:24
Preview
Download
Adobe Portable Document Format - 9.08 MB - 10/29/2018 at 06:43
Preview
Download
ArduiTouch ESP8266 Weather rev A.pdf
Application example for a weather station
Adobe Portable Document Format - 410.82 kB - 10/28/2018 at 14:09
Preview
Download
Adobe Portable Document Format - 207.36 kB - 10/27/2018 at 08:33
Preview
Download
View all 12 project logs
View all instructions
