ADF4351 bluetooth Controller
Control the RF synthetiser from a smartphone
This project allows remote configuration of an ADF4351 breakout board from a smartphone.
Smartphone talks bluetooth to an ESP32 module which in turn talks SPI to the module.
The module stores its configuration to the eeprom and reloads the latest configuration upon startup so the smartphone is only needed to change the configuration.
Files are on github:
https://github.com/joseluu/ADF_4351_BT_Smartphone
  • Code updates
    Jose Luu11/19/2018 at 07:25 0 comments
    Smartphone application: allow sweep mode configuration of frequency step in KHz an step duration in ms (does not work if > 10ms)
    programming of ADF4351 (on ESP32): fast lock mode now works, muxout pin outputs the digital lock signal
View project log
