Code updates
A project log for ADF4351 bluetooth Controller
Control the RF synthetiser from a smartphone
Jose LuuJose Luu 11/19/2018 at 07:250 Comments
Smartphone application: allow sweep mode configuration of frequency step in KHz an step duration in ms (does not work if > 10ms)
programming of ADF4351 (on ESP32): fast lock mode now works, muxout pin outputs the digital lock signal
