• 1
    Decide you want to make keyboard.
    Be very sure you want to make THIS keyboard.
    Still here? Okay let's do this.
  • 2
    Design a PCB.
    Or use mine,
    or redesign mine:
    https://github.com/trisimix/janck
    Here's some tips: don't use fritzing if you are going to print using seeed (a pcb printing service). As of 2018-11-04 fritzings gerber exports don't work with their service.
    I ended up using easyeda, it even has a web interface if you're lazy. Or a linux client if you're not.
    I designed one 100mm x 100mm pcb, you connect up to 3 of them by the dots on the sides, and the rows. This way you can save money and prevent extra pcbs since most places have a minimum pcb amount.
    I missed two connections on my original design below. Oops. Didn't matter.
  • 3
    Print your PCB.
    You can use something like seeed. Or if you made your pcb with fritzing use fritzings service.
