Badge Top Cover.stlReady to print STL of top coverStandard Tesselated Geometry - 880.84 kB - 11/06/2018 at 05:40 |
Badge Bottom Cover.stlReady to print STL of bottom coverStandard Tesselated Geometry - 1.58 MB - 11/06/2018 at 05:40 |
Badge Top Cover.stpSolid model of top coverstp - 953.24 kB - 11/06/2018 at 05:40 |
Badge Bottom Cover.stpSolid model of bottom coverstp - 1.02 MB - 11/06/2018 at 05:40 |
Supercon Badge and Proto PCBAs.stpDesign your own enclosure using my model of the badge and proto boards. Pulled the data to create these models from the gerbers, so it should be fairly accurate. I modeled the front LCD, LED and buttons. On the bottom, I just have the battery holders and batteries.stp - 3.43 MB - 11/06/2018 at 05:46 |
Supercon Badge and Proto PCBAs.stlPrint your own copy of the badge and proto boards.Standard Tesselated Geometry - 41.56 MB - 11/06/2018 at 05:46 |
