Version 1.0 PCB
A project log for Teensy Thumb Keyboard
Handheld tactile switch keyboard for Teensy 3.2 compatible boards.
anthony-digirolamoAnthony DiGirolamo 11/11/2018 at 04:150 Comments
So far so good. Everything works as expected but there are a few minor problems.
  1. Typo on silkscreen label on the breakout header for A9/D23. Appears as A9/D32.
  2. Through hole solder pads on the Teensy breakout are too thin.
  3. Holes for the surface pads on the Teensy 3.2 are useless and not connected to anything. Should probably be replaced with some proto holes.
