DIY Homemade Scania Truck Simulator
This is my first big project building a homemade truck simulator with real scania 4 series parts
This will become a fully functional trucking simulator for ets 2.
It will be made out of:
. Real Scania 4 series parts - such as dashboard, cluster buttons and so on
. A Logitech G29 with Hshifter - to make the steering and the gear levler
. A pc power supply - for things like background lightning, fans an cigaret lighter
. Some pc cooling fan's - to simulate the air coming from the cooling/heat grills
. An Arduino mega 2560 R3 - to control the instrument cluster, the warninglights an the indicators
. A Zero Delay Arcade USB Encoder - for contolling the buttons
. 6 MM MDF - for the skeleton
. Some flex tubing - to run all the wires in
Sorry if you think it's a bit slow gowing, but this is not a sponsored project with a big team of builders an a huge bank account, it's just me putting my own time and money into this huge project
The first 2 button panels is ready to go,
Used a Multimeter tool (set on ohm) to mesure wich of the connectors solded wires on and then just solderd the wires to the conectors
dash_plugin.dll
plugin to make ets 2 work with arduino (telementery data plugin) put it in you ets 2 root folder under bin/X64/plugins
x-msdownload - 47.50 kB - 11/13/2018 at 03:45
Download
plugin.cpp
file for the plugin
cpp - 12.36 kB - 11/13/2018 at 03:45
Download
options.cpp
file for the plugin
cpp - 2.94 kB - 11/13/2018 at 03:45
Download
serial.cpp
file for the plugin
cpp - 3.02 kB - 11/13/2018 at 03:45
Download
serial.hpp
file for the plugin
hpp - 1.89 kB - 11/13/2018 at 03:45
Download
View all 9 files
View all 7 components
  • Almost Completed
    Ronni Bantz05/26/2019 at 18:06 0 comments
    There is not much left to do on the project :) all instruments and buttons are functional.
    The things that are left to do is : Sterring, clutch, ignition and getting a SKRS gearnob for the shifter and a scania seat
  • Frame Building & mounting of the first parts
    Ronni Bantz02/06/2019 at 20:48 0 comments
    So I finally got the wood I needed to start building the actual frame for the simulator.
    For the buttom plate I used a big 1000X2000 cm particle board, the actual framing is made with 38X57 mm lathes.
    The vertical lathes is attached to the buttom plate with angle brackets,  then  it was just a matter of filling in the gabs between them with the horizontal lathes making a square box to mount the parts on.
    Then I started covering the frame with pices it partickel board , very simpel just cut to size with a jigsaw and screwed on to the lathes.
    I then mounted the steering bracket / pedal assembly on to the frame, this was done using the original Scania mounting bracket by drilling holes in the lathes and screwing it all together with some big bolts I had leftover from a mailbox
  • Finished the prepping of the dash
    Ronni Bantz01/26/2019 at 02:31 0 comments
    Finaly the prepping of the dashboard is complete :) Everything is solderet and connectet to the circuitboards. So now i am just wating on the wood i have orderd to build the frame :)
  • Prepping The dashboard
    Ronni Bantz01/02/2019 at 16:35 0 comments
    Finaly i got a hold of the dashboard, so now the project countinus :)
    Started with unscrewing the handbrake (From underneath you unscrew the big monunting bracket ) and disasembling the handbrake. Got rid of moste of the parts and kept only the top.
    I then screwed a srew in to the bottum of the handle so there was somthing to activate the microswitche.
    I screwed som wood on to the big mounting bracket to have somthing to mount the microswiches to.
    Then i mounted the handbreake handle back onto the bracket, alligend the 2 microswitche and mounted them on to the wood,. an put the hole thing back onto the dashboard and wired the microswitche and the emergency blink kontakt to the Zero Delay Usb Encoder that i have mounted in the glowbox  on a pice of plywood.
    Now it is just a matter of soldering the rest of the contactpanels and the cluster and wire them to the usb encoders and arduino
  • Testing the rev-counter is working in ets2
    Ronni Bantz12/01/2018 at 19:37 0 comments
    Just a little test of the newley installed servo's and the arduino programming
  • Starting to asemble the cluster
    Ronni Bantz12/01/2018 at 01:31 0 comments
    Today i recivede some of the servo's so i thought i would start asembeling the cluster again :)
    I started out with drilling and grinding a hole in the back of the rpmcounter, and fitted the servo, then i drilled a small hole in the needel and found a screw that was long enough to reach from the needel to the servo.
    Then i just put the revcounter dial back in place and screwed the needel on to the servo the same thing with the fuel gauge and water temp gauge.
    With the speedometer i started out wirh cutting out a hole in the backplate the servo would fit throug, then mounted the servo with a couple of short screws, drilled a small hole in the needle and assembled the hole thing.
    I also made a small wooden plate to mount on the backside to mount the background light diode to.
  • Starting To Prep The Cluster
    Ronni Bantz11/16/2018 at 02:05 0 comments
    Got some more parts yeastaday (Light diode's, diode mounts an the zero delay usb encoders)so now we move on with prepping the instrument cluster
    Now we need something to actualy mount the servos and diode mounts to, so i laid a pice of paper over the backside of the cluster an made a paper template of where the diffrent holes should be. I then transferred it to a pice of old thin wooden plate i had laying arround
    Then it was just a case of grabbing the drill, the Jigsaw and some sandpaper to make the cluster backplate
    When that was done i test fitted the backplate on the cluster to see if everything fit, an fortunately it did :) Then i skrewed the diode mounts in place (Unfortanley i diden't buy quit enough of them) and put the different diode's in the mounts
    Then i started the soldering work and got a few diode's finished before my soldering iron gave up, here is what it looks like so fare
    So now we are at kind of a stand still until i get a new soldering iron an get some more parts, wich will be around the 1. december. I'm planing on that the next big part i will get is the actual dashboard of a scania 4 series so that we can start building the structure
  • Prepping the first parts
    Ronni Bantz11/13/2018 at 03:43 0 comments
    I have now finished prepping all the parts i have so fare.
    . The instrument cluster - Disasembled ready for mounting of light diods for the warning lights and servo engines for the dials
    . The speedo-drive - disasembled ready for mounting the servo engine
    . All the button panels - i have mesured out wich connectors that are connectet on the buttons with a multimeter tool (set on OhM, when it shows 0 ore you hear a biiiiiip sound you got the right connectors) and have solderet wires on these connectors so they are ready to be connected to the zero delay usb encoder
    So now im just wating for more parts to arrive
View all 8 project logs
Ronni Bantz wrote 06/30/2020 at 20:04 point
Yes i seen your project, it was what Got me startet with mine :)
Yes it had me going for some time to, i made an adaptor in steel to connect the steering wheel  to the original scania steering collum :) more pics Will be comming soon :)
Jeroen van der Velden wrote 11/08/2019 at 08:55 point
Nice, same project as me ;) Looking forward to see your steering wheel solution because this was giving me pain! If you need any code or help, feel free to use my stuff!
https://hackaday.io/project/8448
