Hackaday.io Hackaday.io
Recently Updated Most Likes Newest Project Lists
Courses Tutorials Events Hackerspaces Profiles Hackaday.com Tindie Marketplace
Sign up Log in
MIDI-INOUT
MIDI IN, MIDI OUT module for Arduino
Artis LabArtis Lab
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
10 followers
  • Description
  • Details
  • Files 0
  • Components 9
    • View all
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
754
0
10
6
Team (1)
  • Artis LabArtis Lab
Join this project's team
  • ArtisLab
hardware
completed project
arduino eurorack synth diy midi MIDI In MIDI OUT
This project was created on 11/14/2018 and last updated 2 years ago.
Description
MIDI IN-OUT is an expansion module for Arduino. It provides two ports: MIDI IN and MIDI OUT, to be able to receive and transmit MIDI messages through serial connections.
The MIDI OUT is used for data transmission and it have to be connected to the Arduino TX port. While, the MIDI IN make possible to receive serial messages using the Arduino RX port.
Components
  • 1 × 6n137 Opto and Fiber Optic Semiconductors and ICs / Optocouplers and Optoisolators
  • 1 × 1N4148 Discrete Semiconductors / Diodes and Rectifiers
  • 3 × 220 Ohm resistor
  • 1 × 470 Ohm resistor
  • 1 × 10k Ohm resistor
View all 9 components
Project Logs
Collapse
  • MIDI In-Out now available on tindie
    Artis Lab • 08/20/2020 at 07:56 • 0 comments
    More info here: https://www.tindie.com/products/ArtisLab/midi-in-out/
  • New PCB released
    Artis Lab • 05/12/2020 at 14:05 • 0 comments
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
OR
Arduino Uno shield & sketch to convert the input from 32 switches to MIDI notes via Hiduino firmware
Project Owner Contributor
Organ Pedalboard MIDI Conversion
Johan CronjeJohan Cronje
The 2015 Hackaday Prize
Launchpad is a great device for musicians with many possibilities. Now you can make your own use of it without computer.
Novation Launchpad controlled by Arduino
jounijouni
The 2018 Hackaday Prize
This compact shield packs a serious punch with LTE CAT-1, GNSS positioning, temperature sensor, and voice support!
LTE CAT-1 Cellular Shield for Arduino
Timothy WooTimothy Woo
Using MT7681 module form Seeed and Arduino Leonardo to build a Wifi Arduino
Linkit connect with Arduino baord
Will WhangWill Whang
Going up?
© 2022 Hackaday
Yes, delete it Cancel
You are about to report the project "MIDI-INOUT", please tell us the reason.
Send message
Remove Member
