Lazy choices
A project log for Open Source Comfortable Headsets
Re-purposing aircraft headsets for gaming and reducing noise distractions in the office. A future upgrade may enable it's use during DIY.
joniJoni 10/11/2016 at 10:430 Comments
To bypass messing around with a cheaper sound card which plugs into USB but can't fit both jacks at the same time I decided to buy a more expensive USB hub with sound card and crack it open. This will allow me to connect the circuitry directly and also take power form the hub to bias the mic and power the pre-amp.
I chose a reasonably cheap UGreen one from amazon.
UGreen USB 2.0 hub with integrated sound card
My pre-amp was just a kit from maplin.
