1Step #0 - buy raspberry pi zero
Kidding, but for comparison i really did started with that and configured everything i would like to have from this project on '5$' raspberry zero. So here it is
What is missing on that images is external usb ethernet card and amp that was used in previous project. In fact i will reuse amp setup in every following configuration since amp part is equally compatible with onion, raspberrypi or orangepi configuration. Green relay module will be described later, but is essentially same relay module that i've used in prev project. But back to topic.
Connection goes this way
And this ends HW part. Than SW part
1) Install pulse server
sudo apt-get update && sudo apt-get upgrade -y sudo apt-get install -y pulseaudiowe need to configure system service, that is when pulseaudio is run with --system switch. Then it will load config from system.pa. Therefore we will edit this one
sudo nano /etc/pulse/system.pachange this line to allow local usage for every user
load-module module-native-protocol-unix auth-anonymous=1and enable network server
### enable network server load-module module-native-protocol-tcp auth-ip-acl=127.0.0.1;192.168.1.0/24 auth-anonymous=1then we will create system service
sudo nano /etc/systemd/system/pulseaudio.serviceand add this content
[Unit] Description=PulseAudio system server [Service] Type=notify ExecStart=/usr/bin/pulseaudio -v --daemonize=no --system --realtime --log-target=journal [Install] WantedBy=multi-user.targetenable and start
sudo systemctl daemon-reload && sudo systemctl start pulseaudio.service && sudo systemctl enable pulseaudio.serviceat this point you should see pulse running in processes
and from external device (laptop in my case) you should add this server as target
nano ~/.config/pulse/default.paadd this line (change ip appropriately)
load-module module-tunnel-sink-new server=192.168.1.85 sink_name=rpithen run kill command to sertart pulse.
pulseaudio -knew sink will appear
at this point pulse part is done
2) Sound card and I2S configuration
we will need to enable I2S and configure card but lucky enough our card is compatible with hifiberry-dac hat, so we only need to enable appropriate DT layer.
sudo nano /boot/config.txtEdit those lines (last one is commented - not necessary but i prefer to have only one card for simplicity)
dtparam=i2s=on dtoverlay=hifiberry-dac #dtparam=audio=onthen you need to reboor your pi and find new sound card available
aplay -l card 1: sndrpihifiberry [snd_rpi_hifiberry_dac], device 0: HifiBerry DAC HiFi pcm5102a-hifi-0 Subdevices: 1/1 Subdevice #0: subdevice #0to test sound i use this command
speaker-test -t sine -f 2500 -c 2
you should see beeping sound in both channels
3) last step is to configure relay module. and i will describe it in next instruction since it is exactly the same as for OrangePI. And this project is actualy for latter one, so let's leave something for it.
Next step is actually start adopting this basic setup to OrangePI Zero.
2Step #1 - Connect I2S Sabre sound card
I started working with OrangePI Zero for the sake of price and simplicity. And immediately were struck by the fact that vendor forgot to solder I2S on the board header. In early versions this was solvable by soldering couple of resistors on the board (more details here) but in my revision this possibility was removed. Technicaly speaking the probem is that PA20/PCM0_DOUT pin is used by vendor to enable and disable WIFI module and not available for my use anymore.
This is from early version schematics, but since newer is not published i will work with this one
So what i will do - i will solder out wifi power switch completely (and lose it forever, since i don't need it, but there is also an option also to enable it permanently) and add wire to unit's solder pad.
We are looking for tsot-5 element
![DiodesZetex AP22802BW5-7 Load Switch IC, Power Distribution, 2A, 2.7 → 5.5V 5-Pin, SOT-25]()
And we will find it near wifi chip
(sorry, forgot to make 'before' photo, so this is soldered out state). Pad #3 is where we should solder PA20 header and pad #5 we should solder to +5V to enable wifi permanenty. In my case i skip last part.
Then other connections will look like this:
So far that's it, relay module will be covered later.
Next step is configure Sound Card in Armbian.
3Step #3 - Configure I2S sound card
Since Armbian 5.30 it switched to device tree to setup device perepherials. Along with this change somehow a lot of features lost their support, therefore it is not as straightforward to enable I2S.
I prepeared github repo to do it quickly
So first get it from github
git clone https://github.com/anabolyc/pcm5102a-for-armbian-orangepi-zero cd pcm5102a-for-armbian-orangepi-zeroWe need to add user overlays to enable I2S (disabled by default) and enable sound card on that port
sudo armbian-add-overlay i2s-sound.dtsthis will compile overlay script, put compiled file under /boot/overlay-user and add to /boot/armbianEnv.txt line
user_overlays=i2s-sound
You need to reboot to changes to take effect, but this will not work just yet. Problem is we are referencing to pcm5102a kernel module there, and this one is not included to armbian for some reason. Therefore we will build it on the same board using current kernel sources. So please check if you have build symlink
$ ls -al /lib/modules/$(uname -r)/build lrwxrwxrwx 1 root root 36 Nov 17 13:42 /lib/modules/4.14.78-sunxi/build -> /usr/src/linux-headers-4.14.81-sunxiIif it is missing - just create it manually be running
sudo ln -s /usr/src/linux-headers-$(uname -r) /lib/modules/$(uname -r)/build
Now you ready to build. First command produce pcm5102a.ko file among others. Second will copy it to appropriate kernel modules folder.
make all sudo make installNow we ready to reboot and check if we have sound card listed
$ aplay -l **** List of PLAYBACK Hardware Devices **** card 0: I2Smaster [I2S-master], device 0: 1c22000.i2s-pcm5102a-hifi pcm5102a-hifi-0 [] Subdevices: 1/1 Subdevice #0: subdevice #0Check if new module correctly loaded
$ lsmod | grep snd_soc_pcm5102a snd_soc_pcm5102a 16384 1 snd_soc_core 118784 5 sun4i_i2s,sun8i_codec_analog,snd_soc_simple_card_utils,snd_soc_pcm5102a,snd_soc_simple_cardNote: this will work even if card is not connected, board will output to appropriate pins and it doesn't really care if someone listens or not. So now lets check if audio will produce
And finally i can hear beeping sound in both speakers. Hooray!
4Step #4 - Configure pulse server
This is no different from raspberry lucky enough.
Install pulse
$ sudo apt-get install -y pulseaudio
Edit system config
$ sudo nano /etc/pulse/system.pa
edit this line
add those lines at the end of file
### enable network server load-module module-native-protocol-tcp auth-ip-acl=127.0.0.1;192.168.1.0/24 auth-anonymous=1now lets create ssyted service file
sudo nano /etc/systemd/system/pulseaudio.servicepaste there following content
[Unit] Description=PulseAudio system server [Service] Type=notify ExecStart=/usr/bin/pulseaudio -v --daemonize=no --system --realtime --log-target=journal [Install] WantedBy=multi-user.targetnow lets enabe and start it
sudo systemctl daemon-reload && sudo systemctl start pulseaudio.service && sudo systemctl enable pulseaudio.servicecheck if it is running
$ ps -ax | grep pulse 3444 ? S<sl 0:00 /usr/bin/pulseaudio -v --daemonize=no --system --realtime --log-target=journalGood, lets check from outside device (laptop in my case), edit user's pulse config
nano ~/.config/pulse/default.paAdd line at the bottom (change IP to yours)
load-module module-tunnel-sink-new server=192.168.1.84 sink_name=opilets restart pulse and see if connection is established
$ pulseaudio -k $ pacmd list sinks ... index: 2 name: <opi> driver: <module-tunnel-sink-new.c> flags: NETWORK DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY state: IDLE suspend cause: priority: 9000 volume: front-left: 65536 / 100% / 0,00 dB, front-right: 65536 / 100% / 0,00 dB balance 0,00 base volume: 65536 / 100% / 0,00 dB volume steps: 65537 muted: no current latency: 45,62 ms max request: 6 KiB max rewind: 0 KiB monitor source: 3 sample spec: s16le 2ch 44100Hz channel map: front-left,front-right Stereo used by: 0 linked by: 1 configured latency: 40,00 ms; range is 0,50 .. 200,00 ms module: 18 properties: device.class = "sound" device.description = "Tunnel to 192.168.1.84/" device.icon_name = "audio-card"no we may play some stuff on remote pulse and check sound
This concludes pulse configuration
5Step #5 - Configure GPIO to shut off amp automatically when there is no sound
I will use PA12 to control relay to switch amplifier physically off from mains when there is no sound.
Lets put script first
sudo nano /sbin/pa-monitorput there following contents
#!/bin/bash GPIO=12 gpio_value=/sys/class/gpio/gpio$GPIO/value gpio_direc=/sys/class/gpio/gpio$GPIO/direction function main { init; while (true); do get_state; if [ $state = "SUSPENDED" ]; then off; sleep 1; else on; sleep 5; fi done } function init { echo $GPIO > /sys/class/gpio/export echo out > $gpio_direc } function on { if [ $(cat $gpio_value) != 1 ]; then echo "on: setting gpio to ON" echo 1 > $gpio_value else echo "on: already ON" fi } function off { if [ $(cat $gpio_value) != 0 ]; then echo "off: setting gpio to OFF" echo 0 > $gpio_value else echo "off: already OFF" fi } function get_state { state=$(pactl list sources short | grep output | awk '{print $7}') echo "state is $state" } mainenable it
sudo chmod a+x /sbin/pa-monitoradd it to autostart
sudo nano /etc/rc.localput it there
sleep 5 && /sbin/pa-monitor > /dev/null &now it is time to reboot and connect relay to GPIO12
I soldered this small module (temporarily of caurse:), until i will prepare more accurate version)
Relay itself sits inside amp
And there you go - amp is switched on when audio is playing, and after it is done - after few seconds it is switched off
6Step #6 - configure mopidy server instance
This can be done on any other board in network, but i will use same OrangePi - since now i have lots of resources compared to paspberry zero - at least all this effort will make some sense when i wil utilize added power.
So lets install docker, shall we
$ curl -fsSL https://download.docker.com/linux/debian/gpg | sudo apt-key add - $ echo "deb [arch=armhf] https://download.docker.com/linux/debian $(lsb_release -cs) stable" | sudo tee /etc/apt/sources.list.d/docker.list $ sudo apt-get update $ sudo apt-get install docker-ce
i mount my music from external NAS, so i will create cifs mount for that
$ sudo apt-get install cifs-utils -ycreate credentials file for cifs mount
$ sudo nano /etc/.smb_shareaccesspaste there
username=your-share-user-name password=your-share-password
change file mode
$ sudo chmod 600 /etc/.smb_shareaccesscreate mount systemd service file
$ sudo nano /etc/systemd/system/data-muzlo.mountpaste there
[Unit] Description=Mount Remote Muzlo Storage Requires=network-online.target After=network-online.target [Mount] What=//ubuntu-op-z1.lan/muzlo Where=/data/muzlo Type=cifs Options=credentials=/etc/.smb_shareaccess,iocharset=utf8,uid=1000,gid=1000 [Install] WantedBy=multi-user.targetstart mount service
$ sudo systemctl daemon-reload && sudo systemctl start data-muzlo.mount && sudo systemctl enable data-muzlo.mountnow create service file for mopidy
$ sudo nano /etc/systemd/system/mopidy-docker.servicepaste this
[Unit] Description=dockerized mopidy Requires=docker.service data-muzlo.mount $ After=docker.service data-muzlo.mount [Service] ExecStartPre=-/usr/bin/docker rm -f mopidy-instance ExecStartPre=-/usr/bin/docker pull andreymalyshenko/mopidy:armhf ExecStart=/usr/bin/docker run --name mopidy-instance -p 6680:6680 -p 8011:8011 -v /data/muzlo:/media:ro -v /var/lib/mopidy:/var/$ ExecStartPost=/bin/sh -c 'while ! docker ps | grep mopidy-instance ; do sleep 0.2; done' ExecStop=/usr/bin/docker rm -f mopidy-instance TimeoutSec=0 RemainAfterExit=no Restart=always [Install] WantedBy=multi-user.targetand now usual
$ sudo systemctl daemon-reload && sudo systemctl enable mopidy-docker.service && sudo systemctl start mopidy-docker.service
image will be loaded and after some time mopidy service will fire up
And last step is to assemble it all together. to be concluded
andriy.malyshenko
