SimpleG-end.gcode
G-Code file for when I hit CTRL+C during laser cutting operation. Ensures to home and turn off the laser AFTER the grbl buffer has been cleared. If you run lots of small vectors, GRBL will home immediately. But if you run long straights, the buffer will need some time to empty. In that case, please just turn the laser off by manually switching the laser_on switch on your cutter and let it finish properly.
gcode - 18.00 bytes - 11/18/2018 at 23:14
Download
20180929 - Visicut Settings.vcsettings
VisiCut config file for my grbl laser configuration. Please check it out and modify as needed. Configured to be used with my Inkscape default template.svg
vcsettings - 7.38 kB - 11/18/2018 at 23:12
Download
default.svg
InkScape default template for my laser cutting configuration in combination with VisiCut
image/svg+xml - 5.34 kB - 11/18/2018 at 23:12
Download
SimpleG.bat
Batch File for easy start of cutting
bat - 216.00 bytes - 11/18/2018 at 23:11
Download
