Arduino Color Picker
Arduino Color Picker lets you pick colors from any object around you.
Public Chat
The project I want to share with you today is Arduino Color Picker, a device that will let you pick any color from real life object(s) and display it in convenient way so you can use it for example in any drawing software, GUI web development and much more!
Welcome to my tutorial!
Portable Network Graphics (PNG) - 72.21 kB - 11/18/2018 at 22:37
Preview
Download
List of parts
JPEG Image - 445.25 kB - 11/18/2018 at 22:37
Preview
Download
View all 10 components
  • 1
    Step 1: Parts List
    For this project we will need:
  • 2
    Step 2: Schematics
    Refer to opening video's assembly section and schematic below to see how to place parts on a PCB.
    Use schematic provided above for correct wiring.
  • 3
    Step 3: Design and 3D Print the Case
    After we have measured the parts, it is time to design a 3D case and print it!
    Design
    Here is the link to my design: https://www.tinkercad.com/things/dG47Pr28uwx
    Case above is designed to perfectly fit all the components listed above.
    Front part will hold the LCD screen and color sensor.
    Main 3x7 cm PCB will hold DFRDuino Pro Mini, battery holders and 3 push buttons and will be screwed on the back part from inside.
    RGB LED will sit inside the top section of the back part.
    Power switch will fit in the small hole on the back part.
    Printing
    3D models ready for printing are available on Thingiverse: https://www.thingiverse.com/thing:3223709
    Print settings may vary depending on your printer.
    Supports are needed for battery cover part and front part because front part has a built in distancer to provide distance between color sensor and specimen.
    Assembly
    For assembly instructions please refer to the assembly section of the video provided at the begining.
View all 5 instructions
