Current Build
A project log for Aquariumatic
Automated aquarium monitor with Web GUI. daisychain units can control multiple tank all from the one master unit. PI/Arduino/ESP Powered
Craig HissettCraig Hissett 06/15/2017 at 14:292 Comments
I just wanted to add a picture showcasing my current build using my enclosures from @Hartmut Wendt:
This thing is going to look incredible when mounted in it's display case on the DIN rail!
The DIN rail power supply has arrived today, so I can hopefully start to put together my case as soon as I have the rail fitted.
Mains will be connected to an on/off switch I have, and that switcxh will route the power to the relays and also to the power supply. The power supply will then power the Pi Zero W-based Hub and the Wemos-based Control Unit.
davedarko wrote 06/15/2017 at 16:52 point
shiny and clean, like the kitchen :)
Craig Hissett wrote 06/15/2017 at 17:08 point
Ha ha ha, thank you on both counts :-)
