Full project for iCEcube2 software configured for iCE40UP5K-SG48 FPGA device:
https://cdn.hackaday.io/files/1623976947993248/iCEcube2-retro1t.tar.xz
It's Retro-V v1.0.0 soft core with "Hello RISC-V!" test program ( provided by @Frank Buss ) that is stored as ROM:
Frank Buss: compile like this: riscv32-unknown-elf-gcc -O3 -nostdlib test1.c -o test1
or
riscv64-unknown-elf-gcc -march=rv32i -mabi=ilp32 -O3 -nostdlib test1.c -o test1
void _start()
volatile char* tx = (volatile char*) 0x40002000;
const char* hello = "Hello RISC-V!\n";
while (*hello) {
*tx = *hello;
hello++;
I locked data output 8-bit bus to bottom-left pins of UPduino:
8 LEDs connected to them will "print" message character by character (LEDs show inverted bits):
So it prints:
01001000 = 0x48 = 'H'
01100101 = 0x65 = 'e'
01101100 = 0x6C = 'l'
01101111 = 0x6F = 'o'
00100000 = 0x20 = ' '
01010010 = 0x52 = 'R'
01001001 = 0x49 = 'I'
01010011 = 0x53 = 'S'
01000011 = 0x43 = 'C'
00101101 = 0x2D = '-'
01010110 = 0x56 = 'V'
00100001 = 0x21 = '!'
00001010 = 0x0A = '\n'
Source code is also uploaded to GitLab:
https://gitlab.com/shaos/retro-v/tree/master/FPGA/iCEcube2-test1
As you can see CPU clocked by 24th bit of the counter driven by high-speed oscillator, so it's like 16 millions times slower - in order to visually see what is going on there - blue blink is clock, red blink is write out (a character on 8 LEDs).
Design statistics:
FFs: 336
LUTs: 2211
RAMs: 4
IOBs: 25
GBs: 5
PLLs: 0
Warm Boots: 0
SPIs: 0
I2Cs: 0
HFOSCs: 1
LFOSCs: 0
RGBA_DRVs: 1
LEDDA_IPs: 0
DSPs: 0
SPRAMs: 0
FILTER_50NSs: 0
Logic Resource Utilization:
Total Logic Cells: 2313/5280
Combinational Logic Cells: 1977 out of 5280 37.4432%
Sequential Logic Cells: 336 out of 5280 6.36364%
Logic Tiles: 342 out of 660 51.8182%
Registers:
Logic Registers: 336 out of 5280 6.36364%
IO Registers: 0 out of 480 0
Block RAMs: 4 out of 30 13.3333%
Warm Boots: 0 out of 1 0%
SPIs: 0 out of 2 0%
I2Cs: 0 out of 2 0%
HFOSCs: 1 out of 1 100%
LFOSCs: 0 out of 1 0%
RGBA_DRVs: 1 out of 1 100%
LEDDA_IPs: 0 out of 1 0%
DSPs: 0 out of 8 0%
SPRAMs: 0 out of 4 0%
FILTER_50NSs: 0 out of 2 0%
Pins:
Input Pins: 0 out of 39 0%
Output Pins: 25 out of 39 64.1026%
InOut Pins: 0 out of 39 0%
Global Buffers: 5 out of 8 62.5%
PLLs: 0 out of 1 0%
IO Bank Utilization:
Bank 3: 0 out of 0 0%
Bank 1: 0 out of 0 0%
Bank 0: 13 out of 17 76.4706%
Bank 2: 12 out of 22 54.5455%
SHAOS
