1st test on FPGA
A project log for nedoPC-5
DIY personal computer built around 32-bit version of RISC-V processor
shaosSHAOS 12/13/2018 at 05:140 Comments
Full project for iCEcube2 software configured for iCE40UP5K-SG48 FPGA device:
https://cdn.hackaday.io/files/1623976947993248/iCEcube2-retro1t.tar.xz
It's Retro-V v1.0.0 soft core with "Hello RISC-V!" test program ( provided by @Frank Buss ) that is stored as ROM:
 Frank Buss: compile like this: riscv32-unknown-elf-gcc -O3 -nostdlib test1.c -o test1
 or
 riscv64-unknown-elf-gcc -march=rv32i -mabi=ilp32 -O3 -nostdlib test1.c -o test1
void _start()
    volatile char* tx = (volatile char*) 0x40002000;
    const char* hello = "Hello RISC-V!\n";
    while (*hello) {
        *tx = *hello;
        hello++;
I locked data output 8-bit bus to bottom-left pins of UPduino:
8 LEDs connected to them will "print" message character by character (LEDs show inverted bits):
So it prints:
01001000 = 0x48 = 'H'
01100101 = 0x65 = 'e'
01101100 = 0x6C = 'l'
01101111 = 0x6F = 'o'
00100000 = 0x20 = ' '
01010010 = 0x52 = 'R'
01001001 = 0x49 = 'I'
01010011 = 0x53 = 'S'
01000011 = 0x43 = 'C'
00101101 = 0x2D = '-'
01010110 = 0x56 = 'V'
00100001 = 0x21 = '!'
00001010 = 0x0A = '\n'
Source code is also uploaded to GitLab:
https://gitlab.com/shaos/retro-v/tree/master/FPGA/iCEcube2-test1
As you can see CPU clocked by 24th bit of the counter driven by high-speed oscillator, so it's like 16 millions times slower - in order to visually see what is going on there - blue blink is clock, red blink is write out (a character on 8 LEDs).
Design statistics:
    FFs:                  336
    LUTs:                 2211
    RAMs:                 4
    IOBs:                 25
    GBs:                  5
    PLLs:                 0
    Warm Boots:           0
    SPIs:                 0
    I2Cs:                 0
    HFOSCs:               1
    LFOSCs:               0
    RGBA_DRVs:            1
    LEDDA_IPs:            0
    DSPs:                 0
    SPRAMs:               0
    FILTER_50NSs:         0
Logic Resource Utilization:
    Total Logic Cells: 2313/5280
        Combinational Logic Cells: 1977     out of   5280      37.4432%
        Sequential Logic Cells:    336      out of   5280      6.36364%
        Logic Tiles:               342      out of   660       51.8182%
    Registers:
        Logic Registers:           336      out of   5280      6.36364%
        IO Registers:              0        out of   480       0
    Block RAMs:                    4        out of   30        13.3333%
    Warm Boots:                    0        out of   1         0%
    SPIs:                          0        out of   2         0%
    I2Cs:                          0        out of   2         0%
    HFOSCs:                        1        out of   1         100%
    LFOSCs:                        0        out of   1         0%
    RGBA_DRVs:                     1        out of   1         100%
    LEDDA_IPs:                     0        out of   1         0%
    DSPs:                          0        out of   8         0%
    SPRAMs:                        0        out of   4         0%
    FILTER_50NSs:                  0        out of   2         0%
    Pins:
        Input Pins:                0        out of   39        0%
        Output Pins:               25       out of   39        64.1026%
        InOut Pins:                0        out of   39        0%
    Global Buffers:                5        out of   8         62.5%
    PLLs:                          0        out of   1         0%
IO Bank Utilization:
    Bank 3: 0        out of   0         0%
    Bank 1: 0        out of   0         0%
    Bank 0: 13       out of   17        76.4706%
    Bank 2: 12       out of   22        54.5455%
