Non-destructive window vent
A project log for I want a Laser Cutter!
My Home Laser Cutter Journey
Hari WigunaHari Wiguna 12/24/2018 at 16:420 Comments
Before I start punching holes on the wall, I want to make sure that this laser hobby is not a passing fad for me, so I came up with this temporary vent solution.  I cut foam core pieces to perfectly seal any gaps below the wood and also between the two sliding window panes.
