Arduino Simone Slouchy
Intolerate Your Posture
After several dismissive attempts (3) -- we (both me's) have haphazardly weaved together an Arduino Uno with cardboard, ultrasonic sensor, servo(s) and stepper(s) to remind, pester and intolerate your posture.
  • 1 × Arduino Uno
  • 1 × Cardboard
  • 2 × Servo (High Torque)
  • 1 × Stepper Motor 28BYJ-48
  • 1 × Stepper Driver ULN2003
View all 7 components
  • Elucidation
    Vije Miller05/14/2017 at 08:55 1 comment
  • Slouchy Code
    Vije Miller04/18/2017 at 04:06 0 comments
    // Simone Slouchy (3)
    // VijeMiller
    // TVMiller.com
    #include <Servo.h>
    #include <Stepper.h>
    // Hand
    const int stepsPerRevolution = 64;
    Stepper hander(stepsPerRevolution, 19, 17, 18, 16);
    // Shoulder
    Servo shoulder;
    // Elbow
    Servo elbow;
    // Sensor
    #define trigPin 2
    #define echoPin 3
    // Servo Position
    int pos = 30;
    // What Action Next?
    int state = 0;
    // Distance Adjust (Version 2)
    // int newdis = 0;
    // Serial For  Testing
    char incom = 0;
    void setup() {
      Serial.begin(9600);
      shoulder.attach(12);
      elbow.attach(5);
      pinMode(trigPin, OUTPUT);
      pinMode(echoPin, INPUT);
      // Set Start Position (Servo)
      shoulder.write(15);
      elbow.write(30);
      // Stepper Starts 0
    void loop() {
      // Sensor Sequence
      long duration, distance;
      digitalWrite(trigPin, LOW);
      delayMicroseconds(2);
      digitalWrite(trigPin, HIGH);
      delayMicroseconds(10);
      duration = pulseIn(echoPin, HIGH);
      // Centimeter Conversion
      distance = (duration / 2) / 29.1;
      // Print for Testing
      Serial.print(distance); Serial.println(" cm");
      // IF Slouching || > 5cm
      // But Not NOT In Chair || < 40cm
      if (distance > 5 && distance < 40) {
        if (state == 0) {
          tap();
          // Change State
          state = 1;
        else if (state == 1) {
          grab();
          state = 2;
        else if (state == 2) {
          assault();
          // Reset
          state = 0;
      delay(5000);
      //  if (Serial.available() > 0) {
      //    incom = Serial.read();
      //    if (incom == '1') {
      //      tap();
      //   else if (incom == '2') {
      //      grab();
      //    else if (incom == '3') {
      //      assault();
      // Reset Value (Else)
      incom = 0;
    void tap() {
      // Map Distance for Extension (Coming Soon)
      // newdis = map(distance, 5, 20, 70, 110);
      // Extend Shoulder and Forearm
      // Open Hand
      for (int i = 0; i <= 600; i++) {
        hander.step(-1);
        Serial.println("Open");
      for (pos = 15; pos <= 30; pos += 1) {
        shoulder.write(pos);
        delay(20);
      for (pos = 30; pos <= 90; pos += 1) {
        elbow.write(pos);
        delay(20);
      for (pos = 90; pos <= 145; pos += 1) {
        elbow.write(pos);
        delay(20);
      for (pos = 90; pos <= 110; pos += 1) {
        delay(20);
      delay(1000);
      // Tap
      for (pos = 145; pos >= 110; pos -= 1) {
        elbow.write(pos);
        delay(10);
      for (pos = 110; pos <= 145; pos += 1) {
        elbow.write(pos);
        delay(10);
        elbow.write(pos);
        delay(10);
        elbow.write(pos);
        delay(10);
      // Fold Back
      for (pos = 110; pos >= 70; pos -= 1) {
        delay(50);
      delay(750);
      for (pos = 145; pos >= 70; pos -= 1) {
        elbow.write(pos);
        delay(20);
      for (pos = 70; pos >= 30; pos -= 1) {
        elbow.write(pos);
        delay(30);
      for (pos = 30; pos >= 15; pos -= 1) {
        delay(30);
        hander.step(1);
        Serial.println("Close");
    void grab() {
      // Open Hand
        hander.step(-1);
        delay(20);
        elbow.write(pos);
        delay(20);
        elbow.write(pos);
        delay(20);
        delay(20);
      delay(1000);
      // Close Hand
      for (int i = 0; i <= 250; i++) {
        hander.step(1);
      // Lower On Sloucher
      for (pos = 145; pos >= 115; pos -= 1) {
        elbow.write(pos);
        delay(30);
      // Pull Back
      for (pos = 115; pos >= 80; pos -= 1) {
        elbow.write(pos);
        delay(30);
      // Open Hand
        hander.step(-1);
      // Extend Forearm
      for (pos = 80; pos <= 145; pos += 1) {
        elbow.write(pos);
        delay(30);
      // Fold Back
      for (pos = 80; pos >= 50; pos -= 1) {
        delay(40);
      for (pos = 145; pos >= 50; pos -= 1) {
        elbow.write(pos);
        delay(30);
      for (pos = 50...
  • Notations
    Vije Miller04/18/2017 at 04:04 0 comments
    1. 28BYJ-48 are cheap bcz they are in fact, rubbish -- do not be fooled by reviews documenting "high torque" and "power" bcz they fail to mention they only used these stepper motors to propel insignificantly sized wheeled robots a few paces before over heating and seizing.
    2. Per my review above (Notation 1) may I suggest the alternative of either the purchase of or the modification of a servo to operate at 360 degree rotation -- ref. http://tvmiller.com/index.php?entry=entry160123-07...
    3. A modified version of this code applied distance reference to alter the position of the shoulder servo relative to the actual distance of the sloucher -- due to impatience, disinterest and coherence of my typical distance, the code is commented but easily accessible.
View all 3 project logs
  • 1
    Step 1
View all instructions
deshipu wrote 05/14/2017 at 23:37 point
This is brilliant idea, why I didn't see it before?
Morning.Star wrote 05/09/2017 at 06:43 point
Having fun I see Vije, nice mechanism :-D
