Speed Improvements
A project log for Serial Port SDR
Transmit radio signals using just a serial port? You bet!
ted-yapoTed Yapo 01/01/2019 at 15:141 Comment
Just a quick note about the recent changes in the GitHub code. I added numba (a JIT parallelizing compiler) support to the code. I see around a 10x improvement in execution speed with the new code, although YMMV.
This improvement probably opens the path for live streaming audio transmission, if that's an interesting thing for anyone. The code does not support this at the moment.
RoGeorge wrote 01/02/2019 at 22:05 point
Live streaming will turn it into a great tool.
Worth a try.
:o)
