Bearing design complete
A project log for FAROSH
Fully Automated Revolving Object Storage Hub
zoZoƩ 12/06/2018 at 18:480 Comments
I bought a used 600 mm diameter table for 10 € and transported it back home on the train... Ü
I designed retainer rings for the bearing balls in OpenSCAD and printed them out of PLA. I'm sure it'll be up for the job strength-wise; the component doesn't carry any significant weight, only keep the balls in place. See the diagram:
The .scad file is uploaded in case anyone else wants to build it. As always, it is fully parametric.
Since it's too big to be printed in one piece, I cut it up into identical sections and added alignment pins. I also created an alignment tool to get them in place.
