• Walking Circuits
    Carl Bugeja12/09/2018 at 22:17 4 comments
    MKII test video!
    Now that I have proofed that the idea can work out, I can start designing MKIII.
    PCB Robot MKIII will be made from just a pcb, magnets and a battery. This cheap robot will be ideal for swarm robotics.
  • MKII
    Carl Bugeja11/30/2018 at 22:08 0 comments
    My new light-weight design:
    3 freakin' grams! (Yes I'm going to have a problem with the battery for MKIII but I have a plan)
  • Concept
    Carl Bugeja11/29/2018 at 19:32 0 comments
    This was my first attempt in trying to use flexible PCBs as robot legs!
    As shown in the video this prototype manged to make some small steps but I was expecting a better behavior. These are all the things that needs to be improved for MKII:
    • Align the PCB so that all legs deliver the same amount of force - strongest point is the middle of the coil, if misaligned different forces with different angles are produced
    • Reduce the gap between the PCBs and magnet
    • Reduce weight
