• Spindle taper protectors
    Jose Ignacio Romero12/31/2018 at 06:27 0 comments
    The three jaw chuck has a big opening, as big as the spindle nose, where stock can feed through. That presents a small problem, it exposes the quite delicate collet taper on the (non hardened!) spindle. Judging from some blemishes on the tapers I can tell the previous owner has accidentally hit the taper with a workpiece before so something needs to be done about this to prevent further damage.
    I modified the 3d printed emergency collet model to become a simple taper sleeve, leaving as much bore as possible to feed material through without being tempted to work without it on.
    I printed these in PETG, they fit snug in the inner taper and bore, with just enough clearance to thread on the chuck.
    I now feel a lot safer throwing stock into the chuck without having to worry about the nose taper getting dinged.
  • Top slide lock
    Jose Ignacio Romero12/16/2018 at 08:53 0 comments
    The lathe uses a pretty nice round dovetail system to lock the top slide and mill table accessories. The dovetail is turned on the bottom of the top slide and gets inserted in a hole in the cross slide. This then gets locked with the help of a brass pin which is shaped such that it both makes a wide contact area to restrict rotation and pushes the dovetail against the cross slide for location.
    The milling table has an identical mechanism with the hole in the middle. Accessories that I have and fit the mill table are a really cute milling vise with a graduated rotating base, and a chuck holder, piece that has the same threads as the main spindle and can hold any of the standard chucks. The arrangement is very flexible.
    One problem though is that one of the brass pins was missing, the lathe only came with the lock for the mill table, so I could not use the top slide unless I moved the pin over to the cross slide and added a little extension, as the length is too short. I decided to just make my own pin for the cross slide instead of going through that hassle.
    Cutting it off to the right size was the easy part, the dovetail-facing part of the pin needs to be shaped into a complex curve that intimately contacts as much of the dovetail as possible when locking, to ensure pressure is applied evenly and a good lock can be achieved without marring the soft dovetail. The ideal tool for the job would be a dovetail cutter of the exact same radius and angle as the actual dovetail; since I don't have one of those I had to improvise.
    A good rough starting point was to use the boring bar in the spindle as a crude boring head, set to a radius that is about midway the cone of the dovetail, and the brass pin mounted as if it was a boring bar, with the holder angled to the dovetail angle. That produced a cylindrical profile that contacted the dovetail along two lines in the outside. I checked contact using a dry erase marker (neat low-precision replacement for engineer's blue). To generate the final shape I just iterated several times between marking up the face, rubbing against the dovetail and filing down the high spots. Here's a picture taken about halfway through the process.
    I continued until almost all the dry-erase would rub off against the dovetail, pretty close to the factory one.
  • Grinding attachment (!)
    Jose Ignacio Romero12/09/2018 at 08:40 0 comments
    Looking through ebay I found this little gizmo which is an official accessory to turn the lathe into the cutest little bench grinder. It consists of a steel arbor and an extruded aluminum guard. The arbor threads directly into the spindle nose and can clamp a 1/2" ID, 3" OD, 1/2" thick grinding wheel. The guard is very hefty, it appears they reused the same profile used in their steady rest (which I don't have) with a couple more very heavy gauge sheet metal parts and a plastic window to complete the assembly.
    This is what it looks like mounted on the lathe:
    Grinding on the lathe is probably not the best idea if I want it to last another 40 years, but I don't plan to use this much, and it will come in handy.
  • 3D printed emergency collets
    Jose Ignacio Romero12/05/2018 at 05:22 0 comments
    While measuring the collets for the collet box build I had this silly idea; why not attempt to measure them as accurately as possible, and then make a 3d printed blank "emergency" collet? Plastic collet blanks are available so this is not a totally insane idea.
    I measured the critical dimensions as best as I could with my calipers and put it in a FreeCAD model (dimensions in mm)
    The dimension I'm the most unsure about is the included angle of the taper, it does look symmetrical, and it does seem to be 41 degrees, but it is hard to measure accurately with my current tooling. I 3D printed a few copies of that model in PETG and tried it out on the spindle.
    It seemed to fit fairly well. If you're wondering what those green dots are, they are pins made of 3mm filament (ABS I think) inside some recesses I modeled in the collet "jaws" to prop them open for machining, otherwise they would be collapsed by the nut and not be able to close any more than the machined dimension when in use.
    Then I did a quick test with a drill and 6mm reamer. It would have been better if I had actually bored the hole instead of reaming, as the reamer can wiggle and not make a perfectly concentric hole, but I didn't have the right boring bar at the time.
    I tried chucking some 6mm bar stock and the reamer itself with it and it has more than acceptable gripping force, whatever is secured with it will not rotate inside the collet with light cutting forces. A quick test with an indicator showed about 0.1-0.15mm (4-6 thou) of TIR which is about 10x higher than a decent collet should be, but it could still be handy for gripping an odd sized drill bit or stock when a regular chuck would be too bulky.
    I'm also printing a set in Nylon with a much higher quality printer to do more testing, and also attempt to bore the hole out more accurately. I also plan to confirm the angle as soon as I figure out how to measure it accurately....
  • Collet case
    Jose Ignacio Romero12/04/2018 at 14:13 0 comments
    The lathe came with a set of 8 collets, from 1/16" to 1/2" in 1/16" steps. They came wrapped individually in little plastic tubes, well protected but impractical to use. I had this little wooden box laying around that proved perfect for holding the set for easy access.
    The box came with the partition in the middle, I designed some 3d printed inserts in FreeCAD (fcstd in the project files)
    They are just held by friction, some cushioning foam on the top ensures they don't rattle around.
  • Tommy bars
    Jose Ignacio Romero12/03/2018 at 00:01 0 comments
    Both the lathe spindle and collet nut have a 5/32" hole to accept a "tommy" bar for extra torque when tightening/loosening collets and chucks. The 3 jaw self centering chuck came with a single tommy bar that is 3/16" in diameter. Since I like multi-purpose tools, I turned down the last bit of the diameter on 2 small 3/16" rods to 5/32 like so
    Notice the awesome concentricity, I've got to resurface those jaws...
    Obligatory action shot:
  • Arrival and maintenance item 1: Spindle pulley bushings
    Jose Ignacio Romero11/30/2018 at 06:07 0 comments
    The lathe arrived home very well packaged, opening all those boxes inside of other boxes that contained the different parts of the machine was like Christmas. I could not contain myself, I had to make some chips. So I proceeded to haphazardly put all the main parts together on the floor and flipped the switch on.
    Too busy having fun to take good pictures with good lighting...The lathe ran pretty well, I did a skim cut to the rotor commutator in the picture (from a very chewed up blender), and cut some aluminum and plastic. The cast iron frame of the machine felt pretty sturdy and it could take reasonable chip loads without chattering too much, considering that the ways haven't been properly adjusted or even lubricated yet...
    After I had my 15 minutes of fun it was time to take it all back apart in order to give it the maintenance it deserves. First issue I noticed was a rubbing sound coming from the headstock, after looking carefully I found that the axle that holds the intermediate pulleys between the motor and the spindle were severely crooked.
    Eek!
    I rotated the pulley by hand and to my relief, the shaft was not bent, the pulleys stayed at the same angle during the entire revolution. I took the thing apart and I found the usual suspect.
    The sleeve bearings were worn almost through, the holes severely deformed into egg shapes. Luckily these bushings are a standard part, "Oilite" plain bearings for 3/8" shaft, 1/2" bore and 1/2" long. The installed bearing had a flange 5/8" in diameter, but I saw that the counterbore in the casting could accept a larger flange, so I bought a few with a 11/16" flange from McMaster Carr, part number 6338k415. The old bearings came out pretty easily when persuaded by a pair of channel lock pliers
    All apart
    I also polished the shaft, which got a bit grooved from the wear, but cleaned up reasonably well. The new bushings went in almost a bit too easy, but ended up solid in place.
    Another little detail on the assembly was a pair of Oilite thrust washers between each pulley and their corresponding sleeve bearing, I'm not sure having both bearing sides be sintered bronze is the best idea from a durability standpoint, it is usually best when you have a hard material like steel bearing on the bronze with the oil film in between. Since the spacing was needed to keep the pulleys aligned I lapped a pair of steel washers flat so that they would have a flat and even bearing surface against the flange of the bushing.
    Shiiiiiny
    It all runs nicely when spun in the bearing holder, but when trying to assemble the entire thing I found that the pulleys don't align correctly with one washer at either side, it did seem strange when I disassembled this both Oilite washers were only on the motor side of the axle. I think this will call for custom spacers later on, but I need a running spindle for that! This will do for now.
