Spindle taper protectors
A project log for My Edelstaal Machinex 5
Restoration, modification and documentation of this odd little lathe/mill/grinder/etc
jose-ignacio-romeroJose Ignacio Romero 12/31/2018 at 06:270 Comments
The three jaw chuck has a big opening, as big as the spindle nose, where stock can feed through. That presents a small problem, it exposes the quite delicate collet taper on the (non hardened!) spindle. Judging from some blemishes on the tapers I can tell the previous owner has accidentally hit the taper with a workpiece before so something needs to be done about this to prevent further damage.
I modified the 3d printed emergency collet model to become a simple taper sleeve, leaving as much bore as possible to feed material through without being tempted to work without it on.
I printed these in PETG, they fit snug in the inner taper and bore, with just enough clearance to thread on the chuck.
I now feel a lot safer throwing stock into the chuck without having to worry about the nose taper getting dinged.
