New PCB arrived
A project log for My own "a million times clock-clock"
cheap rip off from the art installation of Humans Since 1982
chaterronychaterrony 08/26/2019 at 19:252 Comments
So, summer is ending and the new PCB arrived after the vacation. The Hall sensor works pretty well. However, the speed is an issue at the moment. Not that I want to run the handles very fast, but the max speed (if both are running at the same time) is roughly 9s/turn. And in addition, when one handle is running at constant speed, it changes speed when the other is accelerating. Seeing all the other attempts on the internet, I doubt that the ATMEGA328p is at his limits. But what is then the reason???
Video can be seen here:
And yes, I did an error on the PCB, therefore I had to handsolder a little bit ;-) Looking for half a hour on the PCB prior to manufacturing is obviously not enough...
Have a good start of the week!
chaterrony wrote 09/02/2019 at 21:07 point
Hello Arne
PCB design has an error for the I2C selection switch. But this is not a big deal.  I have uploaded the PCB design, but be aware of this error! :-)
I used the following components:
Hallsensor: OH49E: https://www.aliexpress.com/item/49E-Hall-element-OH49E-SS49E-Hall-sensor-Hall-Effect-Sensor/32433449139.html?spm=a2g0s.9042311.0.0.27424c4d02L0n4
Magnet: dia3mm, length 1mm: https://www.aliexpress.com/item/10-50-100-200pcs-3-x-1mm-Powerful-Super-Strong-Rare-Earth-Neodymium-Disc-Magnets-3x1/32957114317.html?spm=a2g0s.9042311.0.0.27424c4d0JrBqR
The stepper can be driven directly out of the ATMEGA328. The coil resistance is 275Ohm, which results in 18mA power consumption (plus spikes of course). As I use the microstepping library of @Gijs Withagen (see the corresponding chat linked below), there is no need for another hardware.
As a master I use an ESP32, see the code in the files. This is what is running in my prototype with 3x3 motors.
Link to discussion: https://hac.io/m/276809
good luck, and share what you created :-)
Olivier
arne.meeuw wrote 09/02/2019 at 17:55 point
Hey there - super nice to have some ongoing reports about your project. I am actually pursuing a very similar approach to you and was thinking whether you could share version 2 of your pcb.
Also, whats your approach driving of the stepper motors - do you think clamp diodes should be necessary? Have you measured the current through coils? I am still thinking about utilising a dual-stepper-driver ic.
also - which hall sensors are you using? what size of magnets? currently i'm using a oh49e and 1x2mm magnets...
thanks for any answers :) cant wait to clean up my code and put it out there. what are you using as a master device?
best,
arne
