So I managed to write a top module for the PWM module I came up with. Here it is:
module top( input i_clk12, output o_led); reg reset = 0; wire pwm_out; wire clk_dc; reg[15:0] dc = 0; clockdivider clkdiv(i_clk12, 12000000, clk_dc); pwm #(.bits(16)) pwm0(i_clk12,reset,16'd15999,dc,pwm_out); always @(posedge clk_dc) begin dc <= (dc == 16000) ? 0 : (dc + 4000); end SB_IO #( // IO IP instance .PIN_TYPE(6'b011001) // configure as output ) pin_out_driver ( .PACKAGE_PIN(o_led), // connect to this pin .D_OUT_0(pwm_out) // output the state of "led" ); endmodule
It cycles through 5 duty cycle levels (on per second). Reset isn't used, but that's not too critical here I guess.
This is the pwm code:
module pwm #(
parameter bits = 4
input clkin,
input reset,
input[bits-1:0] max,
input[bits-1:0] compare,
output out
reg[bits-1:0] count = 0;
reg[bits-1:0] compareLatched = 0;
always @(posedge clkin)
begin
if(reset == 1)
begin
count <= 0;
compareLatched <= 0;
end
else
begin
if(count == 0)
begin
count <= max-1;
compareLatched <= compare;
end
else
count <= count-1;
end
end
assign out = count < compareLatched;
endmodule
Pins:
set_io i_clk12 21 set_io o_led 96
This is for #ICEd = an Arduino Style Board, with ICE FPGA
Christoph
