Bootloader Confirmations
A project log for Lerdge 3d Printer Mainboard Hacking
Breaking the encryption on the Lerdge series mainboards so I can try porting Marlin 2.0 to it.
jc-nelsonJ.C. Nelson 12/16/2018 at 15:230 Comments
This log is basically to confirm that two different people have told me the base bootloader works - one on a -S, one on a -X. I'm not recommending you erase your mainboard, but if you do, and you want to go back to the Lerdge firmware, you can. Happy hacking, folks. Next up will likely be USB support.
