There's been quite a break in updates on this project and that's for good reason. I do this for fun, and it stopped being fun. However, after the completion of the Chitu (Tronxy) work, I decided to loop back around. Marlin has evolved, the ST Arduino core has evolved. Everything has evolved...so I decided to start again.
It took quite a bit of messing around but I was able to get Marlin 2.0 running without LCD, building and encrypting automatically for LerdgeX (K is a different variant. The same scripts will be used but you need a different pin set for the variant and I'm not looking at that yet.
The PR is out to add support for Lerdge to Marlin.
No LCD, but you've seen it work (hell, the code is in my repo). With the new TFT support coming to Marlin, it is a matter of time.
You can follow the PR here:
J.C. Nelson
