Lerdge-K bootloader dumped
A project log for Lerdge 3d Printer Mainboard Hacking
Breaking the encryption on the Lerdge series mainboards so I can try porting Marlin 2.0 to it.
jc-nelsonJ.C. Nelson 12/19/2018 at 19:500 Comments
I've added the K bootloader to the files section (and for fun, I dumped past it and found my arduino sketch right where I expected). This will let you restore a K board you've accidentally (or intentionally) wiped the loader on. I was only able to do this because someone sent me a K board (not naming them because I'm not sure if they want to be named). If you'd like to do the same on an S, I'll upload the sketch binary. You let it run, attach, then dump ram. You'll need to work out the ST-Link header pins - I don't know those for the S.
Edit to add - yes, this means I've run my own code on the K now.
