Hooking an ST-Link to The Lerdge X and K - An Illustration
A project log for Lerdge 3d Printer Mainboard Hacking
Breaking the encryption on the Lerdge series mainboards so I can try porting Marlin 2.0 to it.
jc-nelsonJ.C. Nelson 12/19/2018 at 22:385 Comments
I've been asked how you hook an STLink to the lerdge X and K. I have zero idea about the S because I don't own one, but here's a illustration (I checked twice and I think I go the CLK/IO lines right - I usually hook them up, and if I can't probe the chip, reverse them. To describe it verbally, it's the pair of pins one from the right on the bottom row. I hook power to the VCC jumper, GND to the middle pin on any of the servo headers.
Nuno Silva wrote 11/27/2019 at 15:45 point
the file to upload is "lerdgexboot1.0.2.patched.bin" ?  and then can use marlin? sorry for my ignorance but how do i send the file?
plam wrote 12/20/2018 at 14:18 point
Lerdge-X STLink connect - The STL pin numbers are reference to STLink on Discovery Board.
https://imgur.com/U6EaL0u
I use 33 Ohm resistors for the tiny socket pins.
cmshelton2010 wrote 12/20/2018 at 08:14 point
Thanks !  J.C.  I used wire from a wire tie so the pin was small enough to not damage or spread the pin hole and prevent the WiFi module from working plugged back in. the pins that came with my cable where to large.
J.C. Nelson wrote 12/20/2018 at 09:03 point
Were you able to connect?
cmshelton2010 wrote 12/21/2018 at 07:50 point
I haven't tried booting and connecting to the lerdge x, I'm still reading how to do all that.
