It's the last update of this project for 2019 !
A3Ptiles_v2.6_20191229.tgz
I have reorganised the files and directories a bit... More needs to be done but it's satisfying so far and I need to go back to work on the ALU8 unit. It was a good opportunity to test that the library integrates well with other projects so now I'm back to the #YGREC8project for a bit.
See you in the next decade !
Yann Guidon / YGDES
