Aim
I made this Clock because I have a addressable LED strip laying around and I want to use it. Then I saw my room doesn't have a good Clock that matches its walls. So I Decided to make a Clock which can change its colors according to users mood or wall color.
Making Process
I firstly took a 24 x 15 inch plywood board.
Cut LED strip into pieces and paste them on the board
Then After soldering them I cover the whole with a black chart paper
Then paste a thermocoal sheet on top of it and cut the thermocoal with a sharp cutter in shape of 4 seven segment displays along with two holes in center.
Then made my circuit ready using circuits diagram given below
and pasted this all behind the board.
I also ordered a custom pcb for the same from https://jlcpcb.com they provide best pcb prototypes for lowest price from china and ship worldwide fast and secure.
after soldering all my components on my board I removed the breadboard and fixed everything behind the board and covered front section using a thin translucent trace paper.
The clock looks awesome and increase the beauty of wall. customization colors make it perfect for any wall.
If you like this project kindly Subscribe on youtube or visit our website http://robocircuits.com
Thank you for reading!
RoboCircuits
Dave Gönner
Benchoff
Mike Szczys
Ken Yap
