Reversing the PCB
A project log for ST-Link clone repurposing
An ST-Link clone has a powerful MCU, nice enclosure and useful connectors to repurpose it for quite some projects.
gertuxgertux 12/02/2018 at 15:581 Comment
I've started with reverse enginering the PCB and documenting it in KiCad's eeschema.
The result is the schema below, you can zoom in by opening the image in a separate tab/window and use your browser's zoom, it's an SVG so the zoom is very good.
The schema was drawn based on the PCB of one my devices, yours could be a little different but the MCU pin to output pin mapping should be the same, otherwise the ST Link firmware would not work.
Even without soldering or cutting existing traces 5 GPIOs are externally available on 4 pins. Of these 5 pins 2 are PWM capable (TIM4_CH1 and TIM4_CH3) and 1 possible ADC pin (ADC_IN5)
Con Pinn ST-Link Function MCU Pin Main function Alternate functions
1 RST 42 GPIO PB6 I2C1_SCL, TIM4_CH1, USART1_TX
2 SWDIO 27 GPIO PB14 SPI2_MISO, USART3_RTS
3, 4 GND
5 SWIM 45 GPIO PB8 TIM4_CH3
6 SWCLK 15 GPIO PA5 SPI1_SCK, ADC_IN5
6 SWCLK 26 GPIO PB13 SPI2_SCK, USART3_CTS
7, 8 3.3V
9, 10 5V
Matias N. wrote 03/23/2019 at 19:29 point
Hey, would you share your kicad schematic? Do you also have the PCB design?
I would like to repurpose mine and document it by modifying the schematic. Also, I would later make a 3D case for it.
