#include <SoftwareSerial.h>
SoftwareSerial mySerial(12, 13); // RX, TX
#include           //https://github.com/esp8266/Arduino
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include "WiFiManager.h"          //https://github.com/tzapu/WiFiManager
int count=0,i,m,j,k;
int t,t1,t2,t3;
int outputpin= A0;//ds18b20
const int trigPin = D7;
const int echoPin = D6;
long duration;
int distance,d1;
//////////////////////////////////////// ALL DECLARATIONS for CLOUD //////////////////////////////
const char* host = "api.thingsio.ai";                                 // OR host = devapi2.thethingscloud.com
const char* post_url = "/devices/deviceData";       // OR /api/v2/thingscloud2/_table/data_ac
const char* time_server = "www.convert-unix-time.com";             //this is to convert timestamp
const int httpPort = 80;
char timestamp[10];
WiFiClient client;
void configModeCallback (WiFiManager *myWiFiManager)
  Serial.println("Entered config mode");             //*-*-*-*-*-*-*-*-*-*-*-*-*-*if control enters this function then net is not connected
  Serial.println(WiFi.softAPIP());                  // "WiFi.softAPIP() is for AP" , "WiFi.localIP() is for STA",
  Serial.println(myWiFiManager->getConfigPortalSSID());             //if you used auto generated SSID, print it
/////////////////////////////////////// TIMESTAMP CALCULATION function///////////////////////////////////////
int GiveMeTimestamp()
  unsigned long timeout = millis();
  while (client.available() == 0)
    if (millis() - timeout > 50000)
      client.stop();
      return 0;
while (client.available())
        String line = client.readStringUntil('\r');                    //indexOf() is a funtion to search for smthng , it returns -1 if not found
        int pos = line.indexOf("\"timestamp\"");                       //search for "\"timestamp\"" from beginning of response got and copy all data after that , it'll be your timestamp
        if (pos >= 0)
          int j = 0;
          for(j=0;j<10;j++)
            timestamp[j] = line[pos + 12 + j];
void setup()
  pinMode(trigPin, OUTPUT); // Sets the trigPin as an Output
  pinMode(echoPin, INPUT); // Sets the echoPin as an Input
  Serial.begin(115200);     //(19200,SERIAL_8E1) - data size = 8 bits , parity = Even , stop bit =  1bit
mySerial.begin(115200);
  WiFiManager wifiManager;
  wifiManager.setAPCallback(configModeCallback);
