PCB - 3D Startrek Enterprise
40 led flashing 3D space ship model
- 10x10 cm of PCB board
- Attiny85 to individual control 20 LED with charlieplexing
- 40 LED total
- sound output (not working in this version, bug on PCB)
- AAA battery in stand for power
- full 3D construction
- it can not fly :-(
- new simplified version without MCU on way ...
BOM (this is my crazy configuration, you can use 0805 or 0603 LEDS):
  • MAIN BOARD
    - 1x Attiny 85
    - 4x Spring battery holder BCL82PC (KEYSTONE)
    - 4x 47R 0603
    - 1x 100n 0603
    - 1x mode switch PTS810SJG250SMTRLF (C&K)
    - speaker not working now, do not solder
  • PLASMA COILS
    - 10x 3014 blue LED on coil
    (3014 LED is very hard to solder without hot air gun, you can use 0805)
    - 2x 0802 red LED on front - this is side LED
    - 2x 0802 yellow LED on tail - this is side LED
  • DEFLECTOR
    - 6x 0603 blue led
  • MIDDLE BOARD
    - 4x 0802 red LED, 2 on tail, 2 under plate - this is side LED
    (do not mix, use same color)
  • PLATE
    - 1x clear white LED 8mm as bridge
    - 6x 3014 white LED
    - 1x 0805 pink LED, above NCC - 1701 text, soldered on side
    - 4x 0805 white LED, under bridge, soldered on side
    - 1x 4014 green LED as laser
FIRMWARE
  • Attiny85 compiled firmware (hex) and sources in FILES section
  • FUSES: lfuse:w:0xc2:m  hfuse:w:0xdf:m  efuse:w:0xfe:m
    (8Mhz, BOD off)
ENTERPRISE_HEX.zip
Compiled firmware enterprise.hex lfuse:w:0xc2:m -U hfuse:w:0xdf:m -U efuse:w:0xfe:m Just run enterprise_upload.bat
x-zip-compressed - 195.75 kB - 09/25/2019 at 20:59
Download
Portable Network Graphics (PNG) - 22.35 kB - 09/18/2019 at 21:37
Preview
Download
Portable Network Graphics (PNG) - 28.90 kB - 09/18/2019 at 21:36
Preview
Download
Portable Network Graphics (PNG) - 20.51 kB - 09/18/2019 at 20:35
Preview
Download
sch - 362.96 kB - 09/18/2019 at 20:04
See BOM
Download
View all 9 files
  • New simplified board on way from factory
    bobriciusa day ago 0 comments
    I created simply no MCU version, just like desk lamp :)
    Just lot leds, resistors, switch and optional micro USB for power.
  • HEX FIRMWARE
    bobricius09/25/2019 at 21:11 0 comments
    To easy setup firmware I created simple batch to set fuses and upload code for Attiny85
    • just run enterprise_upload.bat
    avrdude -C ./avrdude.conf -v -p attiny85 -c usbasp -P usb -e
    avrdude -C ./avrdude.conf -v -p attiny85 -c usbasp -P usb -U lfuse:w:0xc2:m -U hfuse:w:0xdf:m -U efuse:w:0xfe:m
    avrdude -C ./avrdude.conf -v -p attiny85 -c usbasp -P usb  -i 100  -Uflash:w:enterprise.hex:i
  • No MCU, no animation version ...
    bobricius09/18/2019 at 21:23 0 comments
    Is there interest for easy solder version without programming MCU, static light, etc like desk lamp, usb powered ????
    etc if anybody want this ship but have not arduino / attiny skills or soldering too small leds ... etc only 3528 simplified version ... ???
    comment please !!!!!!
  • Boards for order
    bobricius05/07/2019 at 08:06 0 comments
    NOTE:
  • Soldering completed
    bobricius12/21/2018 at 23:10 0 comments
    lets go to make some blinky software ;)
  • Boards ordered
    bobricius12/10/2018 at 21:26 2 comments
    maybe it is big fail and lost, but I am very exited and I can not wait longer and I can not focus on longer development. Maybe I mixed 2-3 blueprints or more spaceships, I am not Startrek expert, just watcher.
    There is lot of space for improvements ....
View all 6 project logs
Eric Chapin wrote a day ago point
The BRD file seems to be missing outline information, which makes it impossible to generate gerber. I wanted to send the files to different PCB fab (have issues with Dirty PCB) and I wanted a few in different mask color for making them into Christmas ornament including red, yellow, green, blue, purple, and white.
akonitzko wrote 09/24/2019 at 16:05 point
I am interesting for a easy solder version without programming MCU.
Can anyone send me a programmed ATTiny 85 for money ?
bobricius wrote 09/25/2019 at 21:50 point
I put in files compiled HEX + uploader for easy setup. I created item in my store https://www.tindie.com/products/4997/
Falk Brunner wrote 09/17/2019 at 17:21 point
Could you please provide a BOM and an assembly plan. (Yes, I could figure it out by reverese engineering, but this is not the way it's meant to be, isn't ist?) This takes 5 minutes in eagle. I already ordered from dirty PCBs! Great project, nice design!
thekat858 wrote 09/16/2019 at 02:34 point
This looked like a cool project, but as it turns out, $38 is bit too steep for me for 10 PCBs.
My original order was about $20, but I was informed by Dirty PCBs that the product was oversized.  The product price doubled and shipping quadrupled. (FYI - It will cost you $0.50 to get a PayPal refund.)
bobricius wrote 09/16/2019 at 04:23 point
sorry, I need pay bills and buy food for my kids. I get 9$ from order. Dirty pcb have very bad shop interface.
Noxmiles wrote 09/05/2019 at 16:24 point
Is there a part list anywhere? "assembly by pictures, you can use leds as you want" is a bit tricky when you only have these pictures to order the stuff.
bobricius wrote 09/05/2019 at 18:20 point
I create part list.
tbnobody wrote 09/05/2019 at 13:48 point
Do you also provide a BOM or schematic? Without that it's quite difficult to find all parts.
Daniel Zhou wrote 05/16/2019 at 05:13 point
Thanks for you reply. Can i get r gerber files or drawing than i can send to a local pcb manufacturer?I did not find a way to download from dirtypcb.com.
Marcos Chaparro wrote 06/10/2019 at 23:30 point
+1!
Can't ship to my country from dirtypcbs.
Daniel Zhou wrote 05/14/2019 at 07:03 point
Is there gerber that were released?
kimtherock wrote 08/27/2019 at 17:03 point
hi there i would like to build this project is there anyway of releasing the gerbers please as i have a dispute with dirtypcbs.  thanks  kim
Asher Gomez wrote 04/10/2019 at 22:02 point
Live long and prosper @bobricius. Nice project.
Anthony DiGirolamo wrote 01/10/2019 at 17:08 point
Wow! I'd definitely build one of these.
me wrote 01/06/2019 at 03:42 point
Hi, beautiful. the gerber (or pcb) files will be released?
Yann Guidon / YGDES wrote 12/22/2018 at 05:10 point
Now, why don't you make it fly ? :-P
de∫hipu wrote 12/22/2018 at 00:27 point
It's beautiful!
davedarko wrote 12/08/2018 at 11:02 point
I will keep an eye out on tindie for this beauty :)
davedarko wrote 12/22/2018 at 14:37 point
seriously :D
Vincent wrote 12/22/2018 at 23:48 point
Same here!
thelogicofpi wrote 06/14/2019 at 16:32 point
