BOM (this is my crazy configuration, you can use 0805 or 0603 LEDS):
- MAIN BOARD
- 1x Attiny 85
- 4x Spring battery holder BCL82PC (KEYSTONE)
- 4x 47R 0603
- 1x 100n 0603
- 1x mode switch PTS810SJG250SMTRLF (C&K)
- speaker not working now, do not solder - PLASMA COILS
- 10x 3014 blue LED on coil
(3014 LED is very hard to solder without hot air gun, you can use 0805)
- 2x 0802 red LED on front - this is side LED
- 2x 0802 yellow LED on tail - this is side LED - DEFLECTOR
- 6x 0603 blue led - MIDDLE BOARD
- 4x 0802 red LED, 2 on tail, 2 under plate - this is side LED
(do not mix, use same color) - PLATE
- 1x clear white LED 8mm as bridge
- 6x 3014 white LED
- 1x 0805 pink LED, above NCC - 1701 text, soldered on side
- 4x 0805 white LED, under bridge, soldered on side
- 1x 4014 green LED as laser
FIRMWARE
- Attiny85 compiled firmware (hex) and sources in FILES section
- FUSES: lfuse:w:0xc2:m hfuse:w:0xdf:m efuse:w:0xfe:m
(8Mhz, BOD off)
Great project! I also ordered the boards. Unfortunately, there seems to be a problem with the hex file which I have downloaded here. In the video you should see the problem: https://youtu.be/bO3Jmj0WaZk
Is there another version?
