PCB
A project log for EMF Pickup Device
An enclosure for a hacked cassette player pickup and processor so you can listen to EMF waves
david-troetschelDavid Troetschel 12/06/2018 at 20:450 Comments
I started by making a physical cad file of the PCB, sensor and volume control. This will be used to make the case around and decide where to lay out components.
A few things are generalized like the solder pads on the main board but this should make for a good Jensen SCR-68C reference file.
